RC10B4.1 FT/WC
Old 03-01-2012 | 09:17 PM
  #12271
jbrooks39's Avatar
Originally Posted by Timmahhh
The rear hexes are nice... and if a nut isn't fully tight they are less likely to spin on the hex than a pin. The fronts were really convenient, but my c clips gave way and caused issues (had the nut too tight trying to avoid losing a front wheel like the losis are prone to) On a practice lap, the c clip bound the axle when it was rubbing the kingpin, and by the end of the race a bearing had exploded. I'm back to pin fronts since the convenience isn't worth a dnf.
Thank you for the response. I was thinking this was really the only advantage (capturing the pin).
Regards,
JB
jbrooks39 is offline
Old 03-01-2012 | 09:21 PM
  #12272
pink_sleeve's Avatar
If you run factory team harded wheel pins in the front you dont even need the c clip
pink_sleeve is offline
Old 03-01-2012 | 09:31 PM
  #12273
Timmahhh's Avatar
Didn't even know ft pins existed. Im interested though because otherwise i was planning to just abandon the front hexes. Got a link? By the way, what hex are you using that with? Just in case the slot depth differs between types.
Timmahhh is offline
Old 03-01-2012 | 09:37 PM
  #12274
onefast8's Avatar
http://www.amainhobbies.com/product_...am-Axle-Pins-4
onefast8 is offline
Old 03-01-2012 | 09:43 PM
  #12275
Jconcepts
Old 03-01-2012 | 09:48 PM
  #12276
Matt Trimmings's Avatar
Originally Posted by onefast8
Matt, What motor timing are you running that gearing at?
I had it at 7 on a stock spec speedo. Motor timing was at about 3 lines on the reedy. Now I'm at a 72/32 in 13.5 with no boost in the speedo and 3-4 lines on the motor.
Matt Trimmings is offline
Old 03-01-2012 | 11:40 PM
  #12277
easy e's Avatar
Default Gearing
It seems that gearing varies a lot for each motor.. I have tekin 13.5 with RS esc timing boost is all okay what gearing and setting should I use on a med to good size track??
Preferably with an 81t spur bc I bought the jc spur before I realized what was what .. I haven't run the car yet the track isn't finished
easy e is offline
Old 03-02-2012 | 01:12 AM
  #12278
Originally Posted by Asharus
nope, get the sc10 ball diff for proper fitment
So the diff linked (#7678) won't work ? I just bought that diff today I hope it fits.
Also do you guys think I should buy the V2 shocks to upgrade from my stocker's or hold out for the BB's that were in the picture ? Thanks for the help
NYC Diesel is offline
Old 03-02-2012 | 05:06 AM
  #12279
That diff has different outdrives and uses a standard bearing. It will work if you have a b4. If you have a b4.1 you will need the diff designed for the sc10, it uses metric bearings.
Old 03-02-2012 | 05:50 AM
  #12280
Asharus's Avatar
Regards,
JB
I still run standard front wheels and hex rears with 22 wheels. I like the hexes due to the fact I can use the solid FT pins. They will fall out if it's not captured by the JC hex.
The rollpins are prone to breakage. I've lost a main a while ago with my SC10 due to this, and this happened to idrummerboy recently as well. Rollpins tend to break at the worst times.
Asharus is offline
Old 03-02-2012 | 06:16 AM
  #12281
Default Clicking noise when rolling the car
Hi my car makes this annoying clicking noise when i roll the car. I have located the noise, it comes from the engine forcing the pinion to "crash". Cause when i spin the engine manualy it does not "float" meaning it makes smaal jumps, and these makes the pinion crash into the spur making this clicking sound. Is it supposed to be this sound?
I have tried changing the gear mesh, this does not help.
Engine is: LRP X12 Vector 7.5 T , Spru is 81 T (followed the car pack) , and i have "robinson racing 48P Pinon" 21 tags .
LoveYToo is offline
Old 03-02-2012 | 06:21 AM
  #12282
bds81175's Avatar
Moderator
Possibly a bent motor plate or bent top shaft. Can you see the mesh tighten up when you spin the spur gear around by hand?
bds81175 is offline
Old 03-02-2012 | 06:39 AM
  #12283
jurquhart's Avatar
Almost finished with my build...just waiting on my radiopost servo and my tekin rs to come in. I gotta say I can't wait to get this on the track.
Is the stock setup from the manual any good?
jurquhart is offline
Old 03-02-2012 | 06:51 AM
  #12284
racer1812's Avatar
Super Moderator
Sounds like the normal magnetic pull in the motor, which is much more noticeable in brushless motors.
racer1812 is offline
Old 03-02-2012 | 07:09 AM
  #12285
jurquhart's Avatar
Does anyone know the part # for the gear diff that will fit the Worlds edition B4.1?
