RC10B4.1 FT/WC
should be 3degrees inboard tow and 0 degrees on the hub. thats perfect for indoor clay. make sure you run the right tires. check what the fast guys are running. and make sure your toe and camber are set properly (one of the biggest issues with RTR cars)
you can't compare the numbers for the spring rates. I put silver/pink on my car and it was STILL softer than green / brown al though the spring rates are no where near the same. That's why I got so frustrated with the whole BB expirament. I spent too much time chasing the springs and second guessing rather than working on other things.
Oh and silver fronts steered more on my car 99% of the time.
Alright guys pretty excited here. Been running a b4 with extended chassis and v2 shocks with big bore springs. Anyway getting my new worlds kit Fri. Anything not in the kit I should get? About how long does the build take?
I have the FT 1/4 weights and the rear triangles (behind the esc, and behind the rx) are too small. Are there other weights everyone uses?
Stand the weights up in the middle of the chassis against the straight line where the battery is.
TOP makes some nice weights. 10g and 5g sizes.
I really hope the B/T5 have movable weight locations. Its nice to be able to go to a 'calmer' front tire design, and add weight to regain the steering...
Keep us up to date Matt, I'm bummed I wasn't able to make it out there this year. Growing up sucks sometimes. Haha.
I'm sure I'll get to check the BB's out in person at the Jconcepts race here next month.
