RC10B4.1 FT/WC
Old 02-01-2012 | 07:34 PM
  #10771
jirish617's Avatar
Just curious, what kind of handling difference would i see changing spacers in my shocks. Right now my setup is:
Front:
AE brown
27.5 wt
5 .030 shock limters(per the Pual Wynn setup.
2 .030 spacers under the shock tower ballstud on the most inner hole
Rear:
AE green
25 wt
2 .030 shock limiters in the rear shocks
3 0.30 spacers under the rear ball studs most inner hole
I am fairly new to RC so i'm learning everything, and out of curiosity I would like to play with shock limiters more, what kind of handling differences would expect to add or lose some in the front/rear. Physically I understand what the limiter does, it limits down travel. Any help would be appreciated, thanks.
jirish617 is offline
Old 02-01-2012 | 07:44 PM
  #10772
Odin544's Avatar
Originally Posted by 1mrdad
I agree with you a 100% about the driving, and trust me, I have a long way to go before I am consistent. That said, I am looking to the future as my driving "rust" is finally starting to fall off. As far as the price of the battery, at amain it's "only" $105.00. But, back to my original question will there be a tangible difference?
Doubt you will notice any difference at all. From what I've heard the new orion batteries are over rated at 90C. Probably pulling a Maxamps advertising campain. Whatever sells.
Odin544 is offline
Old 02-01-2012 | 07:54 PM
  #10773
Odin544's Avatar
Just looked at orions site.
Thanks to new developments, the Carbon Pro LiPo can now withstand discharge rates of up to 90C.
No where do they list the continous discharge rate. Same stuff Maxamps pulled.
Odin544 is offline
Old 02-01-2012 | 09:42 PM
  #10774
racer1812's Avatar
Super Moderator
Originally Posted by jgenord
Hello All, I purchased a Carbon Top Plate for my B4.1 and there is no hole to put the screw in that you put the body pin in. Is this just a piece of flash that needs to be drilled out or do they not come with the hole?
Thank You,
Jon
checked mine, no hole and it's not just "flashed over". You could drill it out if you wanted to.
racer1812 is offline
Old 02-01-2012 | 10:05 PM
  #10775
ghea's Avatar
Default GHEA pistons
Originally Posted by skengines
Thanks.
Is anyone running the GHEA pistons? If so which ones do you recommend?
Hello,
I would recommend the same # you normally use.
GHEA2065 = tapered #2
GHEA2065F= flat#2
GHEA2066= tapered #1
GHEA2066F= flat#1
In generall I would use Flat pistons for smooth track surface with hard landings and tapered for rough track surface.
Please visit Absolute hobbyz as they distributes our products in the U.S
Thanks.
ghea is offline
Old 02-01-2012 | 10:26 PM
  #10776
Registered User
Thanks.
I ran the tapered GHEA pistons in the rear of my car tonight. It made a huge difference. Our track has a woop section that I could never go through at full speed after trying all different set ups. I even tried the RC Shox 2 stage pistons. With these GHEA pistons I can fly through that section at full speed. These things are awesome
I run the RC Shox pistons in my SC10 and they are awesome in there. I think the buggy is just too light for them
Ryno B4.1 is offline
Old 02-02-2012 | 02:51 AM
  #10777
what did you have in front regular flat pistons????????
motorhead68 is offline
Old 02-02-2012 | 04:40 AM
  #10778
bds81175's Avatar
Moderator
Front:
AE brown
27.5 wt
Rear:
AE green
25 wt
Think of it this way, if you limit down travel you also limit the distance that the chassis can move up under accel/decel. So if you increase the number of limiters in the front shocks you don't allow the front of the car to rise up as much under acceleration. This will give you more exit steering at the possible expense of exit rear traction. If you add limiters to the rear shocks you are limiting the distance that the back of the chassis can rise up under braking. This should give you more corner entrance rear traction and less entrance steering. Make sense?
bds81175 is offline
Old 02-02-2012 | 06:02 AM
  #10779
Registered User
I beleive I still have the 2 stage pistons up front. I will be putting the GHEA in front before my next race I just did not have the time last night
Old 02-02-2012 | 06:07 AM
  #10780
Asharus's Avatar
Thank You,
Jon
nobody uses body pins at my track, just velcro, front and back
Asharus is offline
Old 02-02-2012 | 06:18 AM
  #10781
lip
Default B4 metric?
Is the B4 coming with metric screws? What about B4.1?
Also, what are the bearing differences(part of cars...not exact bearing numbers)?
Thanks.
lip is offline
Old 02-02-2012 | 06:52 AM
  #10782
ben73's Avatar
Thanks.
imperial
ben73 is offline
Old 02-02-2012 | 07:50 AM
  #10783
When switching to the zero degree rear hubs are they still running the carbon camber mount and shaved u brace or is it back to the A and B mount with unshaved u brace
josh short is offline
Old 02-02-2012 | 08:12 AM
  #10784
the big rc's Avatar
I'm running the #2 flat ghea pistons front and back and am amazed at how well they work. Smooth as Kyosho now!
the big rc is offline
Old 02-02-2012 | 08:44 AM
  #10785
jirish617's Avatar
Okay thanks! I am actually looking for a just a little more entrance traction so maybe I'll try adding to the rear.
Only other question, would the same info be true, if I don't brake through turns? I actually don't use my brake at all except for controlling the pitch of the car in the air, I just get off throttle or get on, because I have found my car will spin out if I apply brake. I've turned it down via esc, but then I can't pitch my car forward in the air too well.
