RC10B4.1 FT/WC
Old 08-14-2011 | 08:49 AM
  #5086
Wild Cherry's Avatar
Tech Legend
Originally Posted by idrummerboy13
have you tried tekin?
They tried to get me to use , I gave it to someone else who needed it ...
Also get to run time to time when I help others tune their rides....
Wild Cherry is offline
Old 08-14-2011 | 09:24 AM
  #5087
Brad S.'s Avatar
good for u man u have better luck than me, screw em im going tekin i already can get rid of both of my speedos.
Anyone who doesn't want your broken LRP SXX esc's, hit me up! I may take them!
Brad S. is offline
Old 08-14-2011 | 09:36 AM
  #5088
idrummerboy13's Avatar
ok i have 2 coming back and they will be new in the box. 140 for one. 220 for both.
idrummerboy13 is offline
Old 08-14-2011 | 09:45 AM
  #5089
Tech Legend
Save one cus you will need ....
Just a opinion , both offer the same reliability, the performance is the biggest difference between & goes to the LRP.....
Hope you get returned the new SXXv2's from Lrp, it is so awesome, never had it better ...
Old 08-14-2011 | 09:54 AM
  #5090
ovalracer1m's Avatar
I'm glad you have so much confidence in the sxx v2 esc. I can tell you that the 2 I had worked great, all temps in check , then all of a sudden dead on the track. The new in box speedo and the replacement they sent me, both with the Same issue. Oh yes I could have just sent it back to lrp and have them repair it and sent it back, but it ruined a race weekend and and would rather not keep waisting money on shipping and risk it happening again. Switched brands and never looked back, and no I will not be back. I am not the only one with this issue either, do a quick search and you will see this is not an isolated issue.
ovalracer1m is offline
Old 08-14-2011 | 09:59 AM
  #5091
YEA its a simple waste of time they ran at 140 for me after 10 min and they would just stop, no wires touching.
Old 08-14-2011 | 10:07 AM
  #5092
Tech Legend
Oval , Can be just a little luck of the draw, I see either brand have a few failures...
So you know , I run way more than most do each week .
usually race 3 or 4 days of the week & I also practice on the off days....
I have experience no problems , not one with the Lrp SXX & SXXv2 .....
Many times I have seen racer's with the bad luck get a returned ESC from the manufacture & they again experience a failure.
This happens because they had a bad servo, receiver or just plain-O wiring issues....
So it is all to easy to blame the manufacture , when it was not there fault at all...
See this a lot BTW....
What I'm saying is almost half the time I do see a ESC fail ?
It was owner mistake , not the manufacture ....
Old 08-14-2011 | 10:20 AM
  #5093
Cpt.America's Avatar
What I'm saying is almost half the time I do see a ESC fail ? It was owner mistake , not the manufacture ....
x2
Cpt.America is offline
Old 08-14-2011 | 10:21 AM
  #5094
dirk thomas's Avatar
i dont know about the sxx but i have the sphere comp and have had it for a long while and use it 2 nights a week and 1 to 2 race days a week. and have never had an issue at all i agree that 9 times out of 10 it is an operator error
dirk thomas is offline
Old 08-14-2011 | 11:05 AM
  #5095
x3
momo.75 is offline
Old 08-14-2011 | 11:57 AM
  #5096
burris7555's Avatar
Originally Posted by Ryno B4.1
Do you mind showing that in more detail? I would like to see how you modified the wing mount. I was thinking about doing the same thing and using the thumb screws from the battery strap
I did the same today on my B4.1 and my 22. Worked out pretty good. I just cut the nipple off the wing mount, ground it half way smooth with a dremel and cleaned it up with a nail file then drilled it. All I had on hand as far as 3mm hardware and a counter sunk washer was the Lunsford Fat Boy motor screws but plan on using these screws below.
Picture below is my 22 so don't hate...
http://www.amainhobbies.com/product_...Mount-Screws-2
burris7555 is offline
Old 08-14-2011 | 12:21 PM
  #5097
Buckaroo's Avatar
What's the prefered method for deglazing slipper pads?
Buckaroo is offline
Old 08-14-2011 | 12:40 PM
  #5098
since its my fualt tell me why my esc runs at 140 after 10 min practice runs in 90 degree weather and all my wires are soldering perfectly not close to touching, my battery can put out 200 amps and All my wires are neat and tight. What did i do wrong there?
Old 08-14-2011 | 01:00 PM
  #5099
Asharus's Avatar
you bought an LRP
Asharus is offline
Old 08-14-2011 | 01:23 PM
  #5100
zeakemedia's Avatar
I use a sanding block for drywall. Mine though is well used from projects around the house. I move it back and forth down then up, just one trip down the block and once back up the block, and then turn it 180 degrees. Turn the pad over and repeat. If the glazing is light it works. When I have glazed the pads really good I work at them a little more. A lot of people use a razor knife but I personally feel this will clean the pads more even.
zeakemedia is offline
