RC10B4.1 FT/WC
Old 06-28-2011 | 07:40 PM
  #3586
becdino's Avatar
Originally Posted by James Tanous
-I run an LRP Sxx V2 speed control and LRP X12 7.5 motor
-Why do you need a larger battery Hold down? any 2s lipo should fit just fine.
-Don't know why your motor shaft is too long, what motor is it?
Thanks Tanous,
I was looking at putting in a Velineon 3500.
That motor and ecu can 3s that is why for the larger battery hold down.
That would be the reason for the shaft being to long.
becdino is offline
Old 06-28-2011 | 07:43 PM
  #3587
Armaan's Avatar
Default Which Lunsford Motor Screws to use?
http://www3.towerhobbies.com/cgi-bin...?&I=LXY800&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXXBN5&P=7
Armaan is offline
Old 06-28-2011 | 07:50 PM
  #3588
Jmuck69's Avatar
I use the second ones myself and love them. Never had a motor loose mesh using them.
Jmuck69 is offline
Old 06-28-2011 | 08:09 PM
  #3589
andrew-01's Avatar
I as well use the second one (7932) in everything from 2wd buggy, crawlers, to pan cars.
andrew-01 is offline
Old 06-28-2011 | 08:11 PM
  #3590
Armaan's Avatar
Thanks guys.
Armaan is offline
Old 06-28-2011 | 08:14 PM
  #3591
Asharus's Avatar
Same here, I use #2 on both my SC10 and B4.1. They work great.
Asharus is offline
Old 06-28-2011 | 08:19 PM
  #3592
Armaan's Avatar
Cool, ordered 2 sets from Tower.
Armaan is offline
Old 06-28-2011 | 11:52 PM
  #3593
Wild Cherry's Avatar
Tech Legend
You guys do what you like... im not a fan boy so i run what works. I don't care what label is on the outside. So far, they are superior to the AE shocks in every single way.[/QUOTE]
If you say so , my advise ?
Should of use
the k shock , there way faster then the losi ....
Wild Cherry is offline
Old 06-29-2011 | 12:10 AM
  #3594
I bought 2 pairs of Fat Boy's in 1998 or whenever it was that they came out and they've been great. I can see how the newer ones would be better where space is an issue. I didn't even know they existed, thanks
adam lancia is offline
Old 06-29-2011 | 12:16 AM
  #3595
Should of use
the k shock , there way faster then the losi ....[/quote]
How would you know??, oh thats right you wouldn't...
Shirk is offline
Old 06-29-2011 | 12:37 AM
  #3596
D-Rek07's Avatar
I'm in the market for a new servo for my b4.1. I'm looking for something under $50. What is the best one for by criteria?
D-Rek07 is offline
Old 06-29-2011 | 01:06 AM
  #3597
You'll want something with at least 100oz/in of torque and around .12 sec./60* transit time. A servo is one of those purchases that you can make one of two ways: 1) save some money now by buying a less expensive servo and then upgrading to a better (= more expensive) servo later, or, 2) waiting a little longer to buy a better servo now and saving a little money in the long run. Your call I always try to take option 2.
Old 06-29-2011 | 04:46 AM
  #3598
bds81175's Avatar
Moderator
Savox makes good servos for a little cheaper than the other guys. Folks talk about the 1257 and 1258 quite a bit on here. I've got a 4096 in my B4 that I love.
bds81175 is offline
Old 06-29-2011 | 05:57 AM
  #3599
Asharus's Avatar
Just save a little bit more money and get yourself a 1257TG. They're about 65 new. You can probably catch a used one in the F/S section for around $50. Beware, the Savox servos consume a lot of power and don't like some Rx/ESC combos so you may need a glitchbuster capacitor. Works fine on Airtronics/Novak Havoc Pro SC and Tekin RX8 combos though.
Asharus is offline
Old 06-29-2011 | 06:30 AM
  #3600
JFuel11's Avatar
Default Savox Servos are very nice
I use the 1257 in my 2 and 4 wheel drive buggy and the 1258 in my SC10s. They are great servos, but they do require alot of power. I run a cap on all vehicles just to be safe.
JFuel11 is offline
