Like Tree55Likes
RC10B4/T4 Forum
Old 01-19-2009, 10:18 AM
  #6721
What up?'s Avatar
Trader Rating: 14 (100%+)
The added weight was to help off-set the weight of a 4000 Nk Ml pack...
What is the weight of the car with the lipo set up? Is is too lite for a Roar race?
I just got the set up the other day and it looks good but its still being tested and is changing alot from what was explained to me. So far it looks good on smooth tracks.
What up? is offline
Old 01-19-2009, 10:27 AM
  #6722
Wild Cherry's Avatar
B-4 weight is 53.5 oz with set up as posted above..
Car is very good on the bumps , we had a big event this week-end (N/w ECT 156 entries !!) .
The layout had a big-O bucking wash board and the car was a lot smoother than the older weighted set-ups...
Attached Thumbnails RC10B4/T4 Forum-ect-09-005.jpg
Wild Cherry is offline
Old 01-19-2009, 11:17 AM
  #6723
what does it mean " Contour outside and inside edges" of these Bar Code tires.. ?? I have these tires, and I love them.
BillySnarf is offline
Old 01-19-2009, 11:49 AM
  #6724
Mean`s trim the outer & inside edge of insert...
Old 01-19-2009, 12:21 PM
  #6725
chewiefttc4's Avatar
Trader Rating: 27 (97%+)
I remember them still adding the 1.5 in front of the trans and the 1 up front
chewiefttc4 is offline
Old 01-19-2009, 12:30 PM
  #6726
1 oz in back and .5 oz on the rear chassis, check the "worlds" set-up for the B-4 on Rc10.com....
Old 01-19-2009, 12:39 PM
  #6727
teambighead's Avatar
[QUOTE=Wes Briscoe;5301666]Another thing that I did not see mentioned is buy the plastic replacement parts and not the carbon. The carbon parts will break much easier.QUOTE]
The plastic does break less... But if your track has any sort of grip, the carbon carries much more corner speed.
teambighead is offline
Old 01-19-2009, 12:46 PM
  #6728
Try this for a 'lightweight set-up'
It should be very close to what BT and Pudge are using...
Last sheet I saw they had a slightly longer wheel base with 1/2* rear toe added on the hubs. Also a full length rear spring, but for the grip of my track, the cut spring stablized the car out a little more.
The total car weight is 53.1 ounces. ROAR minimum is 52 ounces.
File Type: pdf
Old 01-19-2009, 01:20 PM
  #6729
What up?'s Avatar
Interesting...... Any one know how much a Reedy 5000 weighs compaired to a Orion 3800? Dont have a scale yet.
What up? is offline
Old 01-19-2009, 03:34 PM
  #6730
Gliptal's Avatar
Default light setup
The 4th hole,
were exactly to drill it, same spacing as the rest? I noticed in the picture above that its not inline with the rest, a little lower.
Gliptal is offline
Old 01-19-2009, 04:23 PM
  #6731
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Just wondering how much to cut off the spring? (ie. coils/length)
DirtyDog3375 is offline
Old 01-19-2009, 04:25 PM
  #6732
aeRayls's Avatar
Drill the 4th hole using the same spacing. Just bolt up a second rear tower overlapping the first and off set it to drill the hole.
aeRayls is offline
Old 01-19-2009, 04:30 PM
  #6733
Trader Rating: 27 (100%+)
Yea thats close to what ive seen them run. I ran my car at 1515 grams all weekend at crcrc and it was pretty good. It just took me a while to get the track down.
AxiomJacob is offline
Old 01-19-2009, 04:44 PM
  #6734
2coils is what I did, it is mentioned on the comments section at the bottom of the set up sheet.
Yup, Thats the easiest way to do it.
Old 01-19-2009, 05:04 PM
  #6735
nsr250repsol's Avatar
What gearing are you guys using in your B4 with 10.5 brushless motors?
nsr250repsol is offline
