RC10B4/T4 Forum
#6707
Exactly. The first couple of months that I was doing RC I was in the same boat. Slow down and learn how the car reacts, work on driving skills. After a couple weeks of doing this (1-2 race days per week) I would go several race days without breaking. Now (1 year later) I rarely break a part on my buggy and am still competative. As for aluminum. The only thing aluminum parts do is cause other more expensive parts to break. The amount of force you are putting on the buggy in a crash isn't changing, the aluminum just transfers the force to another part of the buggy. I would rather break a caster or arm than a chassis.
#6708
+1 on slow is fast too. I haven't been racing long, and I had a 19 turn in the car, now I have a 12 turn. It is a WORLD apart in terms of power. The 19 turn was good as I COULDN'T go too fast, the 12 turn doesn't have that problem!
In the first year I had my car, I only broke towers when I landed on the roof. I did learn to drive properly though, with less power. I only ever broke parts when I did something stupid.
Also, the wide bumper from RPM is fantastic. Protects the entire front end
#6709
Question to you guys:
Would it be more cost-effective/less expensive for me to get a spare B4 for parts? Or should I just keep buying parts from LHS/Online?
Would upgrading all the parts to aluminum help?
It's a lot like flying helicopters...there is a direct and somewhat proportional suckage to breakage ratio. The less you suck the less you break. As your skill improves the car feels more and more durable. My first day at the off road track cost me about $20 in parts...next few times less and less, I haven't broke anything in awhile.
#6711
Current set up, working front to rear;
Front
30deg c hub
camber hole A
2 bump steer spacers
axle height up
trailing steering block
shock mount in on lower arm
position 2 on lower tower
silver spring
std shaft
5x limiters
30wt losi oil
shock in middle position on top tower (2)
Almost bones level
Rear
Med wheel base
2 deg anti sq
outer camber link position (2)
2 spacers underneath camber link
outer hole on rear hub (A)
shock on outer hole on lower arm
middle hole on shock tower
bones level
silver spring
25wt losi oil
2x limiters
additional info
No weight added
using Trakpower 5400 lipo 3/4 forward
78/32
17.5 SP
Any help to remove the push is appreciated
Darrin
Front
30deg c hub
camber hole A
axle height up
silver spring
std shaft
5x limiters
30wt losi oil
Almost bones level
Rear
Med wheel base
2 deg anti sq
bones level
silver spring
25wt losi oil
2x limiters
additional info
No weight added
78/32
17.5 SP
Darrin
#6712
Could you tell me what your throttle curve would be like on a mm setup if you were running a tight high grip technical track? I let someone else try mine out last night and he mentioned that it definitely needed to have more power throughout the range. I currently had have it set low input until you get to about 50-60 percent. Would it be a good idea to have it almost a straight linear 45 degree increase? I have a smc 5000 28c lipo. Also you mentioned putting the timing on low...where would you have punch control set at as well? Thanks.
#6714
hello all, another new guy,
I just bought a T4 RTR,didn't know any better, queston is can I make this truck into a ft truck .....also will the setups off of the AE site work for this truck. any advice on this truck would be helpful as I am brand new to RC racing.
#6715
Just wanted to know if there are any new lipo setups that don't need to add all the weight back in?
I have tried the one already mentioned here a few pages back, and its ok, but on our rough and loose tracks its just not consistent enough and tends to bounce around over the ruts and rough sections.
I see at CRCRC that both Brent's T and Cav cars are both using the softest spring (black) in the rear and seems to have no weight added on the battery bar (leading me to think they are running them light). Can anyone help out?
I was thinking of adding a few weights (14 grams) to the front bulkhead, middle pods around servo and in rear behind battery.
What do you think?
What do you think?
#6716
Edit: taken care of, thanks for the awesome support AE....
#6717
What do you think?
What do you think?
It'll be interesting to see what they publish for setups. AE guys have been working with a no-weight added setup to run the cars very light. There are differences in the front end with these as well as some difference in the rear shock positions from what I've seen.
#6718
Factory Lite set-up update for B-4
ft
shock mount
#1 hole & inside on arm
1 degree camber
.060 under ball stud, #1 hole & A hole (camber link)
rear
shock mount
drill 4th hole on rear tower , inside on arm
#1 hole & .030 under stud, B hole on rear hub (camber link)
bump steer spacer = .060
steering knuckle = middle
wheel base= middle
2 degree anti squat
ft shock
#2 piston , 030 internal limiter, 25w, brown spring, thread bottom shock eyelet all the way
rear shock
#2 piston, 030 internal limiter,25w, black spring
Ft Tires
Jconcept bar code(Gold) rear insert , contour outside & inside edges
Rear Tires
JConcept bar code(Gold) standard insert , no contour
battery forward
Reedy 5000 Li-Po
ride height
rear arm dog bone level
ft arm level
remember , remove all added weight including 1.5oz behind rear tower
Super Fast Set-Up , must do
shock mount
1 degree camber
rear
shock mount
wheel base= middle
2 degree anti squat
ft shock
rear shock
Ft Tires
Rear Tires
battery forward
Reedy 5000 Li-Po
ride height
ft arm level
#6720
