RC10B4/T4 Forum
#6722
Car is very good on the bumps , we had a big event this week-end (N/w ECT 156 entries !!) .
The layout had a big-O bucking wash board and the car was a lot smoother than the older weighted set-ups...
#6724
#6726
#6727
[QUOTE=Wes Briscoe;5301666]Another thing that I did not see mentioned is buy the plastic replacement parts and not the carbon. The carbon parts will break much easier.QUOTE]
The plastic does break less... But if your track has any sort of grip, the carbon carries much more corner speed.
#6728
Try this for a 'lightweight set-up'
It should be very close to what BT and Pudge are using...
Last sheet I saw they had a slightly longer wheel base with 1/2* rear toe added on the hubs. Also a full length rear spring, but for the grip of my track, the cut spring stablized the car out a little more.
The total car weight is 53.1 ounces. ROAR minimum is 52 ounces.
#6730
light setup
The 4th hole,
were exactly to drill it, same spacing as the rest? I noticed in the picture above that its not inline with the rest, a little lower.
#6731
#6732
Drill the 4th hole using the same spacing. Just bolt up a second rear tower overlapping the first and off set it to drill the hole.
#6733
#6734
2coils is what I did, it is mentioned on the comments section at the bottom of the set up sheet.
Yup, Thats the easiest way to do it.
