RC10B4/T4 Forum
#6754
Yes, rayspeed hubs.
#6755
Try this for a 'lightweight set-up'
It should be very close to what BT and Pudge are using...
Last sheet I saw they had a slightly longer wheel base with 1/2* rear toe added on the hubs. Also a full length rear spring, but for the grip of my track, the cut spring stablized the car out a little more.
The total car weight is 53.1 ounces. ROAR minimum is 52 ounces.
#6757
Any light T4 setups out there??
#6758
#6759
#6760
There are a few light weight truck set up's floating around, but nothing is nailed down yet as being 'the set-up'.
The standard issue cav set up for the truck is still very good.
#6761
I got a lipo/lightweight mod. I used it on my b4 and t4..it helps get more weight on the rear tires. You can get a shorter wheelbase by sanding down the rear arm on the hub side to allow you to put in 3 .30 washers instead of 2for a touch shorter WB.
I got an old setup I ran last year in and outdoors (10.5 indoors & mod/6.5 out) only changing the tires and gearing. I was running the light, 200g orion 3200s. I'm sure it could be a little better but it'll get it loosen'd up for a lightweight pack. ..and I didn't add back tons of lead, just what I needed. I won the local summer points series w/ it. I haven't been running truck this year...by the end of the year the JC tires were out for trucks and the goose bumps were awesome!
Link, then download the T4_WhiteHouse_Setup file.
http://www.nashrcracer.com/coppermin...album=26&pos=0
#6763
You can get the Rayspeed hubs from a Yokomo dealer.
It is much easier to get the Racers Edge hubs though.
Part # RCE9436
Part # RCE9436
#6764
Part # RCE9436
Part # RCE9436
#6765
