Team Associated B6.1 & B6.1D thread >
Like Tree1089Likes
    Hide Wikipost
Old 03-24-2020, 06:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday and Roger M.):
Print Wikipost
Old 04-23-2019, 05:21 PM
  #2701
Originally Posted by dowj28
Can anyone share what they use to cool down their motor on a B6.1? Fan size, Type of Mount, placement, cost, pros/cons and its effectiveness.
30mm x 30mm Yeah Racing Tornado mounted on Schaffner Racing Products mount.
blueflagger is online now
Old 04-24-2019, 02:52 PM
  #2702
kyle3333's Avatar
Default What 5mm bullets?
what 5mm bullets are people using? Low profile ones do not really allow the bullet to seat the whole way. All of the 5mm I have found are low profile.
kyle3333 is offline
Old 04-24-2019, 05:08 PM
  #2703
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I am using TQ Wires, TQW2508 5mm Male Bullets Window Top (pr.) Gold 21mm
ZEe_NYC and jtodd57 like this.
Kraig is offline
Old 04-24-2019, 06:23 PM
  #2704
Super08's Avatar
I have been using these ones, nothing special but they seem to work well.
https://www.amainhobbies.com/protek-...k-5022/p244690
Super08 is offline
Old 04-25-2019, 01:08 AM
  #2705
RazorRC's Avatar
You can solder your wires at an angle (like 30-40 degrees up) so they clear the battery strap, or you can use a little bit longer wires so they stick out away from the battery and clear the strap by pointing out to the sides.
RazorRC is offline
Old 04-25-2019, 01:17 PM
  #2706
TommyD2x's Avatar
Originally Posted by pablo101
Can anyone tell me if the b6.1 kit includes the 3 different spring cup heights? Thanks in advance
And an even better question.... What are the advantages of each size?
TommyD2x is offline
Old 04-25-2019, 01:30 PM
  #2707
Super08's Avatar
The higher the cup the more preload.
Super08 is offline
Old 04-25-2019, 01:35 PM
  #2708
Krio's Avatar
Trader Rating: 159 (99%+)
No handling difference. They are there for clearance and compatibility for different length springs.
Use the shortest one you can (they are stronger) without it hitting the arm at full droop, unless your spring is too short and you are close to the bottom of the threads on the shock body for preload adjustment.
Krio is offline
Old 04-25-2019, 01:48 PM
  #2709
Trader Rating: 19 (100%+)
If I want to run the b64 rear arms in my 6.1 do I have to get diff drive shafts
speed101 is offline
Old 04-25-2019, 01:52 PM
  #2710
Krio's Avatar
No. The arms themselves are the same length from hinge pin to hinge pin. Might need to accommodate the narrower shock mounting location somehow, but the driveshaft won't need to be changed.
Krio is offline
Old 04-25-2019, 02:30 PM
  #2711
Trader Rating: 15 (100%+)
Another related question, what is the deal with the long vs short eyelet/shock ends?
dowj28 is offline
Old 04-25-2019, 05:37 PM
  #2712
Super08's Avatar
That can be used to change the overall length of the shock effectively raising or lowering ride height.
Super08 is offline
Old 04-26-2019, 05:57 AM
  #2713
Krio's Avatar
Primarily it's used to keep droop the same when moving the shock locations around. On the front arms, you should use the long eyelet on the outer hole to keep a similar amount of downtravel/droop to a short eyelet on the inner hole. On the rear, if you are running 2 degrees of anti-squat, the long eyelets on the back of the arm will produce similar droop to using the short eyelet on the front of the arm since the arm is angled and the mounting holes are at different heights.
Krio is offline
Old 04-27-2019, 02:31 PM
  #2714
Trader Rating: 29 (97%+)
Can I get a link to a good stock buggy setup for a tight track with lots of jumps to flat. I am traction rolling going from jumps to flats and want a softer setup.
party_wagon is offline
Old 04-29-2019, 03:49 AM
  #2715
Hey guys, I just picked up a b6.1, but I wanted a 6.1D. Got a good deal, and I'll be converting it to the D. With the laydown gearbox, is it just a matter of swapping the internals from the 6.1 over to the laydown box? Also, the only difference I could find between the two kits in terms of parts that I would need to convert to the D, is the rear shock tower, springs, and laydown case - is there any other parts that I need to make the swap?
Thanks.
Push is offline
