Team Associated B6.1 & B6.1D thread
#1951
B6.1d astro
6.1 is only faster when the grips really high for me
#1952
#1953
Super Moderator
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 76 (100%+)
#1954
Super Moderator
I have both cars. In low to medium grip astro the 6.1d car works very well with orange and blue v1 springs fitted. Battery all the way forwards and play with rear link and toe in to suit plus adjusting diff heights and axle heights it’s as quick as my 6.1 car.
#1955
Thanks for the advice. I plan to occasionally drive it on hard packed clay too and I don't intend to have the B6.1 for Astro and B6.1D for Dirt for now. I'm just planning to have one B6.1D to run on both Astro and Dirt. So I was wondering should I sell my B6.1D and get a B6.1 instead for both Astro and Dirt. Once again, thanks for the advice. Much appreciated...
#1956
Anyone running the Schuur Speed V4 17.5 motor? If so what timing are you guys running, or how many amps are you pulling if you have an analyzer? I just got one and im trying to dial it in
#1957
R/C Tech Elite Member
I am. I don't have an analyzer, but the motor is performing well at factory timing/gear ratio for medium size tracks. Getting 120F after a 6 minute main w/out a fan, so I could probably get away with one or two more teeth on the pinion. Idk if it helps but it seems like they set it up nicely out of the box.
#1959
Just wondering, considering the recent Factory Lite B6.1D release, do you think the 6.1 is here to stay for a while? It's already a great kit, there are only a handful of things they could meaningfully improve upon that I can think of, which wouldn't be enough to justify a new kit anytime soon.
#1961
For 99,9% of all Racers: No
#1962
It sure does look cool tho
#1965
So ... The plastic bulkhead breaks, I get that. But, if its replaced with the aluminum version, what's the next component in the chain of failure? Arms? Hinge pins?
