Team Associated B6.1 & B6.1D thread
#1202
There is only one class that we race here which is a hand out 19T brushed motor (with a juststock ESC) and i don't have any idea where it falls on brushless motor
Some people say it falls between 13.5 and 17.5 but some say it falls around 10.5T brushless
Anyone have any idea about this?
#1203
To donnie_p's question, is the 4-gear standup an option any longer on the 6.1? It was on the 6, but that ship may have sailed.
I will disagree with adding weight in the rear. I think that has always been more about ft/rr balance than adding grip (we've argued that point, too..) and in this case, it's just as likely to create a pendulum effect on the loose surface. Guys are running full laydown successfully on decidedly medium grip these days, after all.
I would also steer clear of efforts to lighten the drive-line. A little flywheel effect is probably not a bad thing, and also counteracts the questionable need for adding weight in the back.
Finally, I'd explore softer suspension to slow down the car's reactions.
Lightened up the front end would give the effect as adding a rear weight although it may not as much. Is that what you mean? or I got it wrong?
#1206
#1207
You need to allow the car to transfer weight to the rear end. I accomplished this with V1 springs, and lighter shock oils all the way around. I think I ended up at 27.5 front, 25 rear with white V1 fronts, and green V2 rears. Probably could have gone all the way down to black rears, but it was good enough to get through a 7 minute main reasonably well.
#1208
Has there been issues with the diff catching inside the trans case? I haven’t had time to read through everything to see if it’s been brought up yet. I just built my B6.1 and everything spins freely with the diff out. But when I install the diff it starts to bind up. Its in about two spots. I think it may be the diff screw heads?, but not sure. Issue with the idler gear teeth? I’ve pulled the diff out several times and flipped it around trying to find where it’s catching. But I cannot find anything. Any help or suggestions?
#1209
#1211
Okay, cool. Yeah, I've been hearing good things about the Racing Performer series orange springs...will give those a try in the rear. Thanks man!
#1212
I am ready to build my B6.1D kit and i am going to run strictly on these type of tracks
1. Outdoor, medium size, loose, low grip, dry, dusty and bumpy
2. Outdoor, small size, big jumps, hardpack, dry/damp, medium grip, dusty, bumpy
No indoor high bite clay, no carpet or turf
I need suggestions on what options are a MUST in terms of performance and or handling wise?
Any suggestions given are greatly appreciated
Some good advice already given, I would recommend:
- standup transmission (there is a 3 gear option for the B6.1D which needs a new topshaft and motor plate (the gear cover comes in the kit). You can also drop a B6D 4 gear on, but you need the B6 rear camber plate, shock tower, layshaft etc.
- brass C block - even with standup we use to help with forward bite in bumpy / dusty tracks. Brass D as well if you run layback. For faster / flowing / higher grip take the brass C out.
- V1 springs seem to generate more grip in lower traction / bumpy conditions, but don't land as well. I run green front / black rear in low grip, white / green as grip comes up a bit or the track is faster.
- for durability, I recommend the alloy servo horn.
Standup typical setup:
http://site.petitrc.com/setup/associ...andup4gear.pdf
Layback setup:
http://site.petitrc.com/setup/associ...kShockRear.pdf
Ray
#1213
For running on indoor clay should I use the 6.1 or the 6.1d? The track we run slicks on, and cars can traction roll. I am getting both kits, and would run the ball diff regardless for the track. I am just trying to figure out what rear end package to use (I don't have the electronics at the moment to just set-up both cars). I am thinking I will just start with the "carpet" car
#1214
6.1D = dirt 6.1 = carpet
#1215
