Team Associated B6.1 & B6.1D thread
#2686
Just setting up my radio gear and noticed I need lots of subtrim to get the steering centred.
I am using a 25 tooth horn, before I pull it out and reset it, is this a common issue? I tested it when I built it and took several goes but the 25 tooth doesn't like being vertical.
Now plug the servo in the reciever and turn the car on. At this point you should only have to use 1 to 5 clicks of subtrim to completly center the servo. Then adjust your EPA on both sides and your done.
#2690
#2692
Can anyone tell me if the b6.1 kit includes the 3 different spring cup heights? Thanks in advance
#2693
#2696
Had my first race meeting with a b6.1 and was amazed how well the kit setups went on bumpy astro. I made a few small tweeks buy stayed with the anti roll bars and went to lighter (v1 red front & v1 white rear) springs.
Apart from the top hats coming off of the electronics plate - turns out I installed it upside down, nothing else fell off or broke 😎😎.
#2697
I actually put a drop of CA on those just to help keep that from happening when I pull the electronics out.
#2698
#2699
Can anyone share what they use to cool down their motor on a B6.1? Fan size, Type of Mount, placement, cost, pros/cons and its effectiveness.
