SC10 4x4 Thread
#8417
Doubtful. Kid stuff, then have to run up to Mike's, onroad fuel race there this weekend, need to meet up with someone. If I make HARC it will be after 3:00 before I can get there. Which is okay, I know the layout already. But fuel only, probably will not have even put 4x4 SC on the track yet at that point LOL. Bobby won last time with his Frankentruck, don't let him do it again. That thing is fast though.
#8420
#8422
1. Remove shaft from transmission.
2. Reassemble shaft without belt pulley (see picture in step 4)
3. locate a pin, Perfect size pin for me was the end of a Traxxas hinge pin. find correct size drill bit.
4. I recommend a drill press with a vise. or a very steady hand. Drill hole through the center of the slipper back plate. flat part of slipper disc acts as a guide so it is easy to drill a hole into the round shaft. and this will help you locate the exact position to drill as well.
5. Disassemble, now take slipper disc and notch it so it can slide over pin like a wheel hex. Notch by sanding or grinding the plastic belt pulley so it also slips over pin.
6. cut pin to fit within the square of the slipper disc.
7. Reassamble transmission with pin.
8.Slide pulley on
9. slip disc back in
10. Reassemble and verify that the slipper unit spins without wobbling. if it wobbles. you might need to to grind some material away from the high side to balance it out.
The belt pulley holds pin inside so you never lose it.
You will gain acceleration and braking. more corner entry speed and exit speed. and equal slipper action which makes truck more stable to me.
Sorry for crap pictures/dirty truck. i haven't cleaned it since i raced it Saturday night.
8.Slide pulley on
But all this work is for what? better acceleration and braking?
All this work is for what problems to eliminate?
I keep reading about people having wheelies with this truch? is that why?
isnt this to much thinking for a tiny little "problem"
what is it exactly what you guys are trying to eliminate and gain with this?
help me understand this..
I drive this truck from day one and havent had any issues, just crank down ( lock-up the slipper ) I do drive the clicker engaged 24/7
#8424
Inglish is not my native language, so im having a hard time understanding it the correct way.
Its main advantage is that it avoids all the traction getting concentrated upon the rear half, causing the truck to lift the front (do a wheelie, or lose substantial amounts of power in the front half). This way, the truck has better acceleration, you can push the throttle harder, and it has better on-power steering.
And if you add front saddle packs/ballasted nose things only go better, because not only you get more traction, but also because the transmission works more equilibrated due to the better mass distribution.
#8425
Man, limited wheel selection for this truck. Black Rulux, DE Racing, or black SCTE. WIll the XXX-SCT wheels work also or is the offset different? What about the Proline Protrac, did the problem with wobble get worked out? I run the PL beadlocks on my 2wd.
#8426
just curious.. anyone here running an underbody? what are you using?
http://www.teamassociated.com/parts/details/91168/
is that for this truck?
#8427
#8428
#8429
i wonder if Associated is going to release another upper shaft, and slipper option for the "pinned" setup everyone is going to. thats is a lot of work for this.. and i dont have the resources to make these parts that you guys are doing..
i just bought the truck.. and had to get the swaybar kit.. havent had a chance to use them yet.. but will this weekend..
now i read about the pinning.. this is crazy!!!!
#8430
5Likes
