SC10 4x4 Thread
Hartson ran none.
http://teamassociated.com/pdf/cars_a..._JC_Spring.pdf
Kody ran 7mm under the inside ball stud, and the 8mm riser on the hub carrier.
Too easy.
Because it never happened?
Hartson ran none.
Too easy.
Hartson ran none.
Too easy.
But you right Kody did only use 7mm , I have 8mm myself though ....
C-Onnnnn !
No spin
Why even raise the inside camber stud on tower at all ?
Hartson ran none.
http://teamassociated.com/pdf/cars_and_trucks/SC10_4x4/setup_sheets/SC10_4x4_2012_Numedahl_JC_Spring.p
df
Too easy.
Hartson ran none.
df
Too easy.
..but the SC10 was great..let's hope nick doesn't use this set up..we'd be done, his SC10 is good but not as good as mine..I'd say if he ran Kodys set up he'd be into the 13's in no time at all..
..I was running Kodys set up tonight except I went to 32.5 in the rear..due to the high traction the 30 was to soft..
Well this track was large. About 97% percent nitro. I find it hard to tune my truck on loose dirt very difficult. I ran 4 pins and raised my ride more than normal. I don't plan on going back so I didn't bother to tune that much. The maintenance is high bc of all the dirt. I'm going to rebuild and oil my bearings....strictly clay for now.
Sadly, Revelation is also the exact type of conditions that have caused most of my feelings of dissatisfaction with the AE truck. My current game plan is to run the coupled slipper (which I think really helps on both the run up and air control in supercross style jumps, IMO), and just deal with the fact I'll never have the fastest chassis on a lap per lap basis, and just run it for fun - IF I feel like doing the three or four hour post race overhaul to check the axle bearings, swapping the A arms, and checking out the other stuff that those big off road tracks pound on.
So, when users post questions like this:
He's only half kidding. Indoors, it's awesome. Outdoor, yeah. It might be as simple as my Jconcepts molded inserts I run are too stiff. All I know is my SC10 and RB4.1 are super competitive both indoors and outdoors with only a tire change, and my SC 4w isn't.
That's would be the same reason you grind down the chassis U on the B4.1 and run the C hub (except there you want to raise the roll center, which is why you lower the upper link).
Other than that, I have no idea what's going through your head on that one. I'd be interested to hear it (even if I disagree).
http://www.tsrproducts.com/index.php...3305-13mm.html
From TSR...
The SC10 4x4 shock diaphragms are blended from pure silicone versus the rubber used in the AE versions. Our SC10 4x4 set includes 4 black diaphragms which are soft and 4 orange diaphragms which are firm.
The set has also been recently updated and now includes both soft and super soft pressure foam inserts.
As for your questions regarding the diaphragm set adding soft diaphragms or foams will reduce the rebound effect within the shocks. Our sets allow the use of various settings ex: soft diaphragm / super soft pf insert in rear and soft diaphragm / soft pf in front.
The captured design just means the pressure foam fits within the diaphragm through slits in the bottom of the diaphragm. This design does not reflect any dampening effect just the style of diaphragm used.
We usually run a set up in short course similar to the one in the example above which adds a bit more pre-load to the front shocks while the rear is set soft as possible to improve traction.
From TSR...
be used in our SC104x shocks??(rear, front,both?)
Do i have to use the foams with these?? Do the slits allow these
to be used without the foams?? Do the Orange&Black both have slits??
Any1 else any examples of bladders like these?,
no offense they seem great, but i would like to just get the
diaphragms without the foams, unless i get a better idea of
the advantages of using these palladium foams??
I know there are bladders just like these, without slits or foams,any1?
http://www.amainhobbies.com/product_...ock-Bladders-4
Maybe these?? 13mm OFNA??
Will probably get theses
OI see, the slits are on the opposite side, like the OFNA ones
in the top link??...duh
more info on if the foams, and if they are a must use with either
of these.
THX all
of these.
THX all
[QUOTE=Wild Cherry;10751758]Not the correct answer....
How did you get 8mm under the ballstuds??? I couldn't get the 12mm stud to tighten down trying to run 7.5mm.
These diaphragms seem great!!, but would the palladium foam even
The foams are another tuning option, you can use them front and/or rear or not use them.
The soft diaphragm gives you less rebound in your shock build and the firm are the same as AE's... both a better material.
Posted by Craig
Because you raised the outer (in your case the exact same amount), and you only wanted to lower the roll center, but keep the camber event pretty close to the same as before?
Other than that, I have no idea what's going through your head on that one. I'd be interested to hear it (even if I disagree).[/QUOTE]
G-wiz,
you claimed you did your homework .....
Craig
Question I asked you is a real good one .
No one has questioned why Ae raised the stud so high and thought most here would have a interest in the reason ...
Giving Craig more time to find correct answer..
G-wiz,
Craig
[QUOTE=SOuthernFRIED;10752437]Trim 1m off plastic above metal tab of stud mount.
Happy bday vito!
Craig...
Me biggest issue was in the air....sometimes I wouldn't have any control bc for a while it got windy where as the 8th scales are heavy enough. I don't mind beating her but she held up. also one of my lipos was puffing....prob bc of the beating. Lol
The lady there was telling me it used to be on raod. I forgot to return my badge to get my dollar back.
Craig...
5Likes
