Like Tree5Likes
SC10 4x4 Thread
Old 06-12-2012 | 12:08 PM
  #24916
ryanpatrickgore's Avatar
Just pulled the trigger on the factory team yesterday. I'm gonna build it all this week then hit trcr ASAP.
WC I'll be looking for you, maybe you might have a few setup tips to help dial it in? I seen how fast your truck was last week....
ryanpatrickgore is offline
  #24917
Cain's Avatar
Tech Legend
Originally Posted by Wild Cherry
Been using what the Ae's drivers do & share with everyone what I learn.
When they tell me something new ?
I bring to everyone ...
Any of them Say how they like the RCShox center diff?
Cain is offline
Old 06-12-2012 | 12:12 PM
  #24918
Cameron Kellogg's Avatar
One asked me about setting it up, said he had one but has not run it yet.
Cameron Kellogg is offline
Old 06-12-2012 | 12:26 PM
  #24919
Wild Cherry's Avatar
Tech Legend
tonight ?
bring her over
happy to help
cain
none around here Cept Cameron have used that I know of ...
Wild Cherry is offline
Old 06-12-2012 | 12:40 PM
  #24920
WC-
I wish, gotta build it first. Might take a few, as the scheduld is sooo full. This weekend im hopeing. thanks much
Old 06-12-2012 | 01:04 PM
  #24921
Oasis's Avatar
30 years racing >>>me
never question his set-ups either
bet they work , love to hear about & all...
Me 27 years..and was fast for about 15 of em..
Oasis is offline
Old 06-12-2012 | 01:22 PM
  #24922
fq06's Avatar
Anyone try putting there SC104x4 on one of those alignment tools like Integy or Hudy? Curious if it can be done.
I use my hudy 1/10 TC setup station.
The toe plate does not fit as the tower is in the way... may take that off next time to get an exact toe measurement, its just a pain cuz of the shock standoffs.
Now I think about it, cant take the sbock tower off during setup for obvious reasons
I use a flush mount screw washer to keep the camber plate flush otherwise there is a shoulder on the axle that extends too far. Washer between the hub and camber plate.
Works great.
fq06 is offline
Old 06-12-2012 | 01:23 PM
  #24923
Tech Legend
personally ? always been a little quick , but have never faster then now ..
Still believe can do even better ..
Old 06-12-2012 | 01:30 PM
  #24924
Originally Posted by Evil Genius jr.
I tried that but the camber link hits the shock spring.
I swapped the rear hubs L/R to mount the C-Tab and I have 1mm between the spring and the turnbuckle. If yours rub, you can always shim the shock bushing back 1mm or so. The angle on the rear turnbuckle looks really screwy without swapping over....at least to me.
F_ME is offline
Old 06-12-2012 | 01:43 PM
  #24925
SMR 510RR's Avatar
My responses are in blue.
2.The suspension is absorbing some of this pressure, we know this because the right tire is lifting up.
Absorbing?
Yes, absorbing. If the tire "lifts" while the chassis leans that means that there was extra downward pressure that is no longer going to push down on that tire because the spring absorbed the energy. A stiffer spring, swaybar, or suspension (roll center) is changing where the force goes.
3. Not all of the weight that has transferred is being directly applied to the tire.
Clarification for what you mean exactly by "not ... directly applied to the tire"?
The pressure that would have been applied if we had no suspension (assuming a perfectly flat surface) would have been higher than the amount of pressure pushing down on the tire after you factor in the energy that was absorbed by the spring, swaybar, and suspension.
4. With a surface that has ample traction (lets say for a moment that it is ideal and there is no slide) there is no need for the right tire to lift, in fact if it pushed down it would actually help us get MORE traction.
Yes and no. Yes because the higher traction surface you are on, the less need for weight transfer (or lift as you called it) and this is exactly why stiffer springs or swaybars are used on on high traction surfaces. If there is no need to generate more traction, you want to minimize losses due to chassis sway and the like. No, because with the chassis leaning over there is literally more weight on the right side. Since the sum of the forces must equal zero in a constant state system (which this is for a sitting chassis that is leaning over) there is more pressure being placed on the tire since there is more weight on it. There is no lost force. You are thinking of a state of acceleration when you say if it 'pushed down' it will generate more force. If the spring pushes down harder than there is weight on the chassis, the chassis accelerates upwards. In that instant you will have more traction, but as soon as you stop the chassis from accelerating up it is gone.
On the higher traction surface you naturally have more weight transfer than on the looser surface assuming that the vehicle weight and speed is the same. See this is where it gets confusing. Assuming that two of the exact same car/truck took the same corner at the same speed and everything was the same except for the suspension (one stiffer one softer) there would be the same amount of weight transferred assuming that neither lost traction. The inertia is being redirected from straight ahead to towards the left, but from what we know about inertia it does not want to move. Since the center of gravity is higher than the surface we are turning on the weight of the chassis is rolling to the right. Now here is the majic, the car/truck with the stiffer suspension is resisting the roll much more than the other car so more downward force is being applied to the outside tire and less to the inside tire than the car/truck with the softer suspension. Just because one car leans over more does not mean that it is transferring more weight. Focus on where the weight is going rather than how much is transfering. With a soft suspension it is constantly more even across the left/right sides of the chassis than with a stiffer suspension.
If you want to see this concept in action watch a fast drag car launch. Your initial thought would be that the best launch would transfer a bunch of weight to the rear, the suspension would squat, and the car would launch and be gone. In reality, most fast drag cars do not squat at all they actually stay rather level or the rear of the car lifts (anti-squat) getting the maximum amount of force to transfer from the chassis directly to the tires and then into the ground.
They don't squat because they don't need more traction. They are trying to resist blowing over backwards. If you don't need more friction at the tires you want to minimize those losses. Let's look at another drag racer; the snowmobile. We drag race them on all types of surfaces... asphalt, grass, snow, and even water. Comparing the asphalt drag snowmobile that has literally unlimited traction to a snowmobile on grass or snow that don't have unlimited traction you will see two completely different results at launch. The asphalt sled acts just like a dragster. The snow/grass racer squats so much the front skis are hovering over the ground as all the weight transfers to the rear to maximize the available friction.
They do need traction, on a perfect flat surface with tons of grip you get the most traction by maximizing how stiff the suspension can be. This may not translate as well because it is a polar opposite to our situation but I know this is true.
Of course it is different in our application because we are A. Talking about turning and B. on a sub optimal surface. The challenge becomes figuring out if the suspension reaction is too stiff causing too much weight to be applied or too soft absorbing more of the weight that should have been transferred. In all reality (not quite sure but it should be right) the same amount of weight is transferring from left to right its just where it gets absorbed or transferred that we are trying to control.
Again, too soft doesn't 'absorb' anything. The force gets to the ground no matter what.
Are you sitting at a desk? Good...Grab a pencil and grab a rubber band. Take the pencil and put it down on the desk so that the end is hanging over enough for you to grab it, make sure the rubber eraser is away from you. Now grab the end, transfer weight from your side to the end (lift it up a little and push down) and try to push it away from you. Now grab the rubber band and do the same exact thing. What one transferred more weight into the "tire"? Your rubber band (spring) is absorbing the energy and storing it for later, when the weight is lifted it goes back straight. Now I think one of the important functions of the suspension is to "dampen" the shock of the weight transfer so that it comes on evenly otherwise there would be too much energy too fast and you would loose grip very quickly. Its all about balance, the weight of the truck is always pushing on the ground its just a matter of where it is pushing. Remember this test was of two polar extremes.
I think I confused you because I was only talking about one tire in my initial response, its more of a right vs. left who gets the force rather than it magically disappearing. In place of the pencil vs. rubber band experiment you could do a similar test with an onroad car vs. offroad car. Put them on scale, roll them over and see what the scales tell you. You could of course try it on your truck and just swap springs between the softest and hardest you have to make sure chassis setup isnt playing a roll.
SMR 510RR is offline
Old 06-12-2012 | 01:49 PM
  #24926
SMR 510RR's Avatar
WC-
Buy yourself a powered screwdriver if you dont already have one...Best $35 I have ever spent for this truck!
Old 06-12-2012 | 03:00 PM
  #24927
My final responses in green before I should probably just pm you to avoid mucking up the thread.
Absorbing?
Springs don't absorb energy though; they store it.
Again, springs don't absorb energy and swaybars just transfer it. Forces don't get absorbed and vanish.
I'm sorry, but most of this is just incorrect suspension dynamics. Pardon the choppy response, but I'm going sentence by sentence. If the weight and speed are the same, a higher traction surface has more potential for weight transfer as you can carve a tighter corner. No, the same amount of weight is not being transferred. The softer car will roll more so the COG will shift more to the outside placing a greater load on the outside (see a later paragraph as to why), thus transferring more weight. Yes, the inertia is being re-directed. Yes, the COG is above the surface we are turning on. Yes, the car is resisting the roll much more but that does not translate to more pressure on the outside tire (again, see a later paragraph). It is exactly because the chassis is rolling that more weight is being placed on the outside tire. "Focus on where the weight is going" is where you need to re-think your physics. No, a stiffer car will have more even pressure on all 4 tires through the same corner compared to a softer car.
No, you don't maximize traction by how stiff the suspension is. You minimize chassis roll on high traction surfaces by how stiff the suspension is. If what you say were true they would be running much higher angles on the trailing links to stiffen it even more.
This experiment needs some refinement. Here's my version:
Have a postage scale and a hanging scale? Good...Grab that pencil again. Take the pencil and put it on the scale so that the end is hanging off. Place one finger in the middle of the pencil and hook the hanging scale onto the end that is hanging off. Lift up with the hanging scale until just the eraser is on the postage scale and then continue to pull up on the hanging scale while pushing down in the middle of the pencil so it stays on the other scale. Look at the forces on each scale; they are identical. The pencil doesn't flex, so there is very little displacement, but the same force applied at one end is applied at the other. Now go get one of those plastic rulers that flex like crazy and usually ended up broken within days. Perform the same experiment. Once again the force you pull up on with the hanging scale matches the force measured on the postage scale. What changed? The distance you had to pull the hanging scale to get the same force. This is what springs do in a steady state: conserve forces. If I push on a spring on my desk with 1 lb of force, no matter how stiff or soft the spring is the spring will be pushing against the desk with 1 lb of force. A stiff spring my only compress 1 cm and a soft one may compress 5, but it doesn't matter. The force placed on top of the spring in a steady state is the force that is exerted at the bottom of the spring.
Here's that paragraph I referred to earlier:
There are 2 primary forces determining how much weight is placed on each tire - the weight of the car (center of gravity) and inertial forces based on acceleration. For a turn of the same radius and velocity the inertial forces are identical if the COG doesn't move up or down. When you soften up the springs/swaybars and allow the car to roll you are allowing the COG to shift. This is more blatant with soft springs and the COG moves towards the outside. The spring doesn't absorb/eat/dissolve/eliminate any force; it just compresses further if it is softer which places the COG even further to the outside. Better yet, the suspension arm is moving in as it compresses shortening the distance between the COG and the contact patch which means more force is required to supply the same 'torque' moment on the chassis. When people want to remove traction from either end of the car, stiffer springs or swaybars are used. Car is over steering mid corner? Stiffer front swaybar/springs or softer rear swaybar/springs.
Krio is offline
Old 06-12-2012 | 04:26 PM
  #24928
driver5150's Avatar
With the exotek chassis do people like the pro 4 4000 or 4600?
driver5150 is offline
Old 06-12-2012 | 04:33 PM
  #24929
Depends on the track size. Small to medium are more than fine with the 4000, but some people are left wanting at large tracks.
Krio is offline
Old 06-12-2012 | 05:25 PM
  #24930
SMR 510RR's Avatar
As it turns out...
We are both wrong and sort of right at the same time. Roll stiffness has no affect on total side to side weight transfer whatsoever, it only affects how quickly weight transfers. The stiffer suspension will transfer more quickly than the soft suspension.
I found some interesting links that talk about it:
http://www.ozebiz.com.au/racetech/th...transpge2.html
http://www.6speedonline.com/forums/9...uspension.html
Some interesting stuff there.
So applying that with the fact that we are on a less than perfect surface typically the truck will grip better with a softer suspension but will have quicker handling with the firmer suspension so in the end it all does come down to balance. Trying to find the softest suspension that will still change directions as fast as possible is the ultimate goal and balance front and rear stiffness to correct any handling problems at different points in the turn. The first link has some very good information that will help figure out what to change for different handling problems such as turn in understeer or exit understeer ot whatever other problem you could have.
Who would have thought there was someone out there smarter than I am? Fluke!
