SC10 4x4 Thread
I just installed it last week and raced with it a couple times. I can't speak of it's stand-alone performance as I also installed the Ackbar, saddle packs, and extra lead at the same time, but here's a first impression rundown:
Pros:
Gets rid of random rear end step-outs
Acceleration is smooth and straight
Cons:
A little less punch than the extra slipper pad setup
From what others have experienced it is fail proof as long as your spring isn't completely shot. There isn't much adjustment on it right now, but there is a V2 on the way with more adjustability in the bias department and Marcus says V1 will be easily upgraded to V2.
The jist: If you are on anything but a very high traction surface go for it since upgrading to V2 will be cheap and easy. If you are on a very high traction surface its a toss-up depending on your driving style. Once V2 comes out this should be a non-issue as well.
Pros:
Cons:
Pros:
Cons:
Pros:
Cons:
Krio, do you think the loss of punch was directly from the diff or a combination of the extra weight? Something that can be fixed with gearing, or maybe by stepping up to the 4600 Pro4?
I've tried the center diff on carpet, noticed it had less punch too. Motor temps ran hotter. I'd guess it was because I didn't need any throttle control. Ill run the garo's till I can get back on dirt.
Geared at 15/60 or 16/60 I know the raw power is there as hitting the face of a jump I can spike the throttle and launch as far as I want. I keep perfect pace with the Losi's going down the straight with the center diff, but I used to pull away a couple feet before. However, the car is so much more planted (again not necessarily just from the center diff) on the infield I have more "racing lines" to pick from and I gained ~5 seconds over a 5 minute qualifier.
I would then have to let them pass again as we got to the more technical sections they were kicking my ass in due to, again much better skill and that they were doing much better tire prep and getting more grip.
Only down side that I've see is that it's expensive to start with, but afterwards I think you can buy the parts separate or potentially find your one replacement parts (balls can be found anywhere, if you have a good drill press you could drill your own spur, order or own washers for the rings, etc.)
Also, at lest with the current version, you can't "Lock down" the front and rear like you can with the pin mod if that is something you require. I prefer to have them decoupled and like the center diff approach better than the slipper since slipper just wastes energy as heat.
P.S. on the price, it seems high compared to the zero you should have to spend on using the stock slipper, but consider a basket + HD pads are going to cost $20 at least, and when compared to a SC10 2wd diff at $35 it's not too far off considering it's a hand-build product.
I was having to slow down before the ramp and gas it at the lip to stay level.
I'm running the exotech with inline saddles and a flotek body. No extra weight added.
I run the 4.0 sonic 550 with the LRP TCspec v2 . depending on how big the track is you r running at will determine the size of the motor. I would recommend the 4.5 and gearing 62/14 is a good starting place.
Just curious because I run the Tekin speedo and software 222 has mad crazy brakes. Just was thinking that maybe the MMP speedo's don't have that hard brake hit that the Tekin's do. A soft brake engagement would not give the rotation as a hard stop would.
I also have a question, wouldn't you get more air control running the sc10 4x4 with the clicker on?
5Likes
