SC10 4x4 Thread
#8401
#8402
I also wonder if the front diff should have lighter oils in it when it's pinned?
#8403
Most important change is it wins now.
#8404
#8405
probably wed at MM. i went up to 7k in the rear too and will be testing the V2 pistons as well, they feel good on the bench, should provide more pack with lighter oils. hole size is now 1.0/1.1 and the top piston has a tighter fit while bottom is looser. if it goes well i will offer two specs.
#8406
#8407
The pulley has to go on after the pin is in the shaft. Meaning the backside of the pulley has to have some material removed. I removed a little more than was needed.
#8411
The changes are not being done by everyone, as people are having mixed results..
1. Mac the Knife's clutch basket
2. B44 Saddle pack conversion
3. sagging arms. New RPM replacments # 73962, and 73942
4. RC SHOX's Dual Garodisc
5. "pin" upgrade, see posts above
I'm sure I'm leaving stuff out, but for the most part that is what has been done to mine.
#8413
#8414
They have a suggestion on their site. http://theohiorcfactory.com/The_Ohio...tory/Home.html About half way down on the left side of the page. They suggest both front and rear AKA Grid Irons Super Soft for 4x4s.
#8415
5Likes
