SC10 4x4 Thread
#7656
I've been running the 19F 20R "Overdrive" combo and I find it helps with my driving style on my track, which has a few sweepers on it, plus I find it helps me keep the nose up when jumping (more RPM up front to help get a little more gyro effect when punching the throttle in mid air).
NEVER run 19 on both, you will never get the belt tight enough and it won't do you anything different than running 20 on both.
#7657
--Its all metric sizes.
2.5mm, 2.0mm and 1.5mm hex drivers
7mm and 4mm (i think its a 4mm) socket drivers
#7659
I wanted to try that today but didn't get a chance. I will get some yellows and give it a try for sure. I also feel my 3800 isnt keeping up with most of the guys at the track. I feel like I am racing a 2wd SC against 8th scale buddies. The other guys stop mid way up the face of a jump and then punch it and double or triple out. I have to hit it with a running go.
#7660
It's different for the front and rear...your pully for the front has a different hub than the pully for the rear.
Of the 4 pullys that you should have, the 20 for the front and the 20 for the rear have no markings. The 19 for the front is marked with an O and the 19 for the rear is marked with a U.
#7661
#7663
Speaking of kindergarden crafts, this past weekend's RCPS Canadian Nationals looked like the first few heats were going to be very wet, so I quickly made an inner-body for both my 2wd and 4wd out of a Pepsi bottle and some zip ties. Will post pics later, but it worked perfectly!
5Likes
