SC10 4x4 Thread
#151
Tip :
If you need new rims the losi fit, but be aware the rim is a bit thicker and you may wish to use a brand new lock nut or lock-tite the wheel nut .
cause
a wheel may fall come off during your run if the lock nut is so , so ...
cause
#152
Australia has the truck and Canadians are still waiting.... explain THAT one...
Does anyone have an actual length that the servo wire needs to be to get to the receiver box WITHOUT extensions? I have no issue running extensions if my Savox won't reach, but would like to know if I need to go get one now, before the truck arrives, rather than get the truck finished and have to wait for my LHS to open the next day so that I can get one...
#153
Just finished pulling the RX8 and sc4x out, Savox out and cleaned too...I'm psyched. Getting it finally after 3 months!!!
Great thread so far...I will kit tomorrow as well....and post info I come across.
#154
#155
Shipping to Australia from China (Assuming thats where the kit is made) is probably quicker than to the US.
#156
Shipped from Tower on Friday (sat our time),
Arrived here at lunch time tuesday (monday your time).
I claim the first SC10 in AU!? Another local Aussie is also getting his today also as far as i know.
Tower & UPS pulled Through foe me
Here is the UPS Path it took to get here http://wwwapps.ups.com/tracking/trac...02200471530886
Justin! here mate!
#157
Well, I got mine today from the big brown truck. Started sorting everything out. Then building. Pulled the diffs apart to check the fluid level as it had been mentioned of low levels of fluid. Mine was low too. Everything was smooth as could be until I got to the outer rear hinge pins. One has threads and the other is smooth as silk. (no threads cut) just wanted to share for QC purposes.
Glad I could help with you catching the low diff oil" I'd bet theres alot of
guys putting them together and never bothered to take them apart to
check the diff oil to see if it's low...
They'll be alot of twitchy SC10 4x4's running around tracks everywhere
because the diffs hardly have any diff oil in them I'd bet..
#158
#159
My lhs should have mine in the morning, I have a mamba monster and 1410 waiting patiently for a home.
For the record to anyone thinking about the sct system, get it and don't look back, the motor is worth it alone, and the spedo will work great in a buggy or stadium truck.
#160
This thread has shit for pictures. Does no one have cameras?
#161
#162
https://picasaweb.google.com/1113101...31478/SC104x4#
so i built some sway bars for the car, since it badly needed em. used ~2.1mm piano wire for the bars. for the links i used AE 1/10 lower shock mounts on the arms and stole the bar joints from my B44 swaybar kits. the chassis mounts for the bar were made from a sheet of ABS, i cut to the right dimensions and slotted for the bar to clamp in.
i highly recommend Chris Jarosz's setup if you run on high traction clay.
#164
i promise ill break it in half
oh wait thats right we spent the day makeing the track "10th scale friendly" ill still find a way to break something i bet
