Like Tree5Likes
SC10 4x4 Thread
Old 05-10-2011 | 11:37 PM
  #301
Started my build tonight. A couple of notes:
1. I wish the shock trees where harder plastic as the shock mounts dig into the channel which is supposed to hold them while you tighten the nuts on the back. (pg 14 & 15) I'll be happy to upgrade to aluminum shock trees when they come out.
2. I am not sure if my 5 mm nut driver shrunk, but I had to use a 7/32 nut driver to tighten all of the 5 mm nuts. (try to figure that one out)
3. I hope that they come out with aluminum 12 mm hex, because it's going to suck if the 12mm plastic hexes stick to the wheels everytime you remove them (and drop the axle pin). This is major flaw. Anyone found an aluminum 12mm hex which is a direct replacement?
oitz is offline
Old 05-10-2011 | 11:41 PM
  #302
Well I found another goof up, while building the tranny, in the manual it says to slide the idler gear on with the skirt side away from the London side of the top shaft for both front and rear, however the AE tips video specifically says to pull the top shaft out a bit and install the idler gear skirt in, on the same side as the longer top shaft. So what way is it supposed to go?
I'm gonna toss it in the trash if I have to tear it back apart!
Dragrcr is offline
Old 05-10-2011 | 11:42 PM
  #303
Cult Racing's Avatar
the wheel situation, idk how your having that problem, when i take my wheels off the wheel comes off nothing else, like the hex or pin. so maybe you didnt push the hex in while pushing the cva axle towards the hub so it kinda like clips in, well thats what I did and no problems.
Cult Racing is offline
Old 05-10-2011 | 11:46 PM
  #304
Originally Posted by Chuck 21
Call AE CS tell them what happened and they will take care of you instantly.
AE will not stand for customers having problems with their kits. They are
probably the best CS R/C car company out there, if not their darn close to
the best.
Give them a call, you won't be sorry... (do not email them) pick up the
phone....
Yea, I got mine home and built to bumber bag as well...and I am very impressed w the truck. U need to have some AE tricks, like tighten the trans bolts ever so gently...and not to over tighten diff screws, things that rotate, go slow with. U can very easily free up the diff and trans tho!
1 more question to u builders how many shimes are u using I'n the rear to keep cva pins in ? also need shimes for front, like 3 each hub...any body else have this problem?
JMD51 is offline
  #305
I haven't checked yet but being the wheel off set is the same as my SCTE
Losi the Losi ones might fit or even better maybe my locking one from my
Kyosho SC-R will fit? I'll be looking into this asap...
Chuck 21 is offline
Old 05-10-2011 | 11:53 PM
  #306
[QUOTE=ilanstylz;9093916]Anyone?[/QUOT
I put a 5.5 SC4X 550 I'n mine, and plenty of room. I think the Tekin is small tho...
JMD51 is offline
Old 05-10-2011 | 11:56 PM
  #307
[QUOTE=JMD51;9094062]
Originally Posted by ilanstylz
Anyone?[/QUOT
If your saying its small, then why are people using them in the losi ten scte which is about a pound heavier then this truck, im sure the 4.5 and 5.5 would work awesome in this truck.
Old 05-11-2011 | 12:00 AM
  #308
the losi wheels do fit perfect, i put my new DE losi wheels on yesterday:
Old 05-11-2011 | 12:25 AM
  #309
SaladFork's Avatar
Damn Cult you have been busy lol, now I know wth you have been.
SaladFork is offline
Old 05-11-2011 | 12:31 AM
  #310
good job. thanx.
catbirdx02 is offline
Old 05-11-2011 | 01:04 AM
  #311
Wild Cherry's Avatar
Tech Legend
Actually got it last Thursday from my local track....
LRP SXX V2
Novak 5.5
XP DS 1015 servo
REEDY 40c 5000
Wild Cherry is offline
Old 05-11-2011 | 01:13 AM
  #312
Done for the night building, got to the bumper bag, all electronics are installed, threw some tires on from my son's Blitz and took it out fron at 2:30 in the morning. Good thing it is a quiet running Truck lol. Will finish it up tomorrow after work. Took about 6hrs non stop to get to this point. Followed the bags with each step in the book and the build went quite well.
Didn't see any flaws in the directions, if you sort your screws by size when you open a bag it makes it a bit easier as you build.
I put the skirt of the idler gear on the outside (same side as the screws of the diff) Wasn't making any noise when I ran it so I would stick with the directions in the book.
Keep'N It Cool is offline
Old 05-11-2011 | 02:27 AM
  #313
[QUOTE=Cult Racing;9094067]
Yea, small as I'n dimensions, as discussed I'n the question regarding "who has installed a 550 can that fit well". I was just answering the question.
JMD51 is offline
Old 05-11-2011 | 02:54 AM
  #314
BLbound's Avatar
I started my build this morning. Did you guys have the castor blocks already installed on your front a-arms? I did...I uninstalled them to take out the steering stop button head screw and then put them back on...just found that it was odd.
So far my gear boxes are rolling smooth...I built them exactly as the instructions say regarding the idler gear.
BLbound is offline
Old 05-11-2011 | 03:21 AM
  #315
Doodad's Avatar
LRP SXX V2
Novak 5.5
XP DS 1015 servo
REEDY 40c 5000
Poor SaladFork.
Doodad is offline
