SC10 4x4 Thread
sorry it took so long to respond. as for setup wise saddle up front truck would corner well but really loose on power out of the turns . inline for me, im able to push the truck harder into cornering very planted out of turns.
I do know the slash 2wd fronts, more offset than the 2wd rears, add 30mm to the wheelbase.
The 4x4/2wd rears wouldn't add that much, probably closer to 24mm.
Should be perfect then. Right now with the stick & stock center Chassis I have some push on power coming out of the corners.
I did use torque limiting which should make things easier on the internal BEC in the MMP. How long did it work for you before you had a problem?
My saddle packs are getting closer!
Louisville, KY, United States 19/01/2012 21:57 Registered with clearing agency
Anchorage, AK, United States 19/01/2012 14:48 Departure Scan
19/01/2012 10:41 Arrival Scan
Chek Lap Kok, Hong Kong 19/01/2012 17:45 Departure Scan
Louisville, KY, United States 18/01/2012 15:10 Registered with clearing agency / Shipment submitted to clearing agency
18/01/2012 11:57 Registered with clearing agency / Shipment submitted to clearing agency
Chek Lap Kok, Hong Kong 18/01/2012 21:07 Origin Scan
Kowloon Bay, Hong Kong 18/01/2012 15:54 Collection Scan
Hong Kong 18/01/2012 12:20 Order Processed: Ready for UPS
I have some electronic questions for you Pro 4 experts. This will be my first attempt at running 4x4 SCT so this is what I am thinking for electronics.
MMP ESC or RX8 ? (opinions welcomed)
Tekin 4000KV Pro4 motor
Savox 1256TG servo
65C Stick Pack LiPo
Ideas, suggestions etc. I have always had good success with the MMP in my Ve8 running the T8 1900KV in sensored mode so that is why I was looking at one for this truck. Is the RX8 that much better? The RX8 just seems hard to find in stock.
Thanks in advance as I am sure I will have plenty more questions.
Savox 1256TG servo
65C Stick Pack LiPo
5Likes
