SC10 4x4 Thread
The FastLap's brace uses these washers
http://www.amainhobbies.com/product_...sunk-Washer-10
And there blue to make it look FT
I was going to use that washer as the Lift Spacer. then a standard blue washer above. FT BABY!
I think I may have found a way to fix wobbly diffs. You cut down where the 10x16x4 bearing rides to about 1.25mm tall, then you can place a 5x10x3 bearing(AE91156) inside the other bearing for the outdrives to ride in.
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
I was trying to think of a way to get rid of those damned bushings, but I never thought to cut up the diff itself.
Son, you just blew my mind. Very Interesting!
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
NICE FIX!
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
I chucked a dremel cut-off wheel into a drill-press, brought the base up to the correct height with the diff case flat on the drill-press base, then moved the diff case to the side(into the cut-off wheel) and sliced it off.
Thanks, BTW i just noticed your post count. That has to be the best first post ever!
what "correct height" are you using? I've noticed inside the brass bushing thing that there is a small groove right where it looks like the outdrive o-ring would sit....is that where you're cutting it?
5Likes
