SC10 4x4 Thread
#7621
anyone? I have read quite a bit here in the last two days, I have seen the one with the traxxas rocker arm mounted along the center line but still can't find the post on the longer carbon tube one. I would like to order the stuff all together and don't want to order too much. I think it was 1/4" but I would appreciate someone to confirm or correct what I think I remember.
Thanks in advance.
Thanks in advance.
#7622
Lets talk set ups people I'm very pleased to say I finally feel that my set up has gotten to be real drive able now and getting closer to the feel of the 2x dialed. So I'm running 30000 front 10000 rear 20 front pulley locked down Mid tight belt front and rear. Center top and out side on all shock locations yellow front spring on tack star oring in the front 32.5 he sway bar all around rear blue spring 27.5 two turns out shock end all emulsion style rear one xring stock. Stock slipper works great locked down dual hd pads with vented slipper. Rear suburb 2.0 stock front tire. And wow at Ocrc the best track in the west coast of the northern hemisphere this thing is dialed oh and tekin 5.5 teking rx8 geared 58 16. Stoked it's come along way now just practice prActice practice. What's your set up please chime in!!
Check out a vid if some other sc 10 also
http://vimeo.com/23237409
#7623
Quick summary of my setup..........
Front: 32.5 shocks (mix), 2 stage piston, yellow springs, 10k diff, 2.0 swaybar, suburbs mc, clicker off
Rear: 27.5 shocks (mix), 2 stage piston, blue springs, 5k diff, 2.0 swaybar, suburbs mc, rcshox slipper pads
RX8/Tekin Pro4 4000kv motor geared at 15/60
Ride height 22mm front, 24mm rear............
-1.5 camber all around..........
Its pretty much dialed to my liking, I'm going to mess around with the diff fluids next rebuild and try out maybe yellow springs in the rear etc....... Other then that its set perf. for me...........
#7625
I am really surprised to see people going to the yellow springs. I bought white springs all around and am running 35wt in the front and I believe 25 in the rear.
works well on my track. medium grip clay indoor bumpy tight track.
3-4 turns out on rear shock ends and 5mm shim on front inner upper control arms. 1 degree camber all around. Double Dee's in front and rebars on rear.
castle 3800/mmp 13/62 and a 3300 45-90C nanotech battery in stock location. about 5-6 oz lead all over chassis.
#7626
Very tight track with a quad ( I can't make the quad)
#7627
#7628
Prize.
I got my MMP together with a 7700kv I used to run on the Lazer ZX5 for somewhere around $170 new. Later on sold the motor in $70 and got a new 1410 in $65. So for $165 I got a very very decent combo.
All the alternatives I browsed were the LRP SXX, which was $229 alone without a motor, and the RX8+SC4X, which was well above twice the MMP+1410 combo.
For me, it was a no brainer.
#7629
Noticed that with spur gear off (doing the push the car to see if its free rolling test in a straight line), the belt will gradually become tense on the upper portion as the car rolls then it'll "decouple" relax again. Tense>relax...repeat. Is this normal?
#7630
Are you running a 19 pully in the front? That will cause extra tension on the belt.
#7632
Had a little trouble with what you are talking about, make sure front and rear pully tensioner are on the same setting, and not to tight. If the belt is overtightened, then it tends to jump the pully. Also check and make sure that pully on rear has not rattled loose.
#7633
Try yellow in back inside hole on top and inside on arm. Run yellow fronts too. At the sc showdown in Dallas it required skill to not overshoot the doubles and end in the middle of the sweeper.
#7634
#7635
Whites are way too soft and the chassis will hit the face of the jump and scrub off speed.
) I can't make the quad because I can't get straightened out soon enough to slam the throttle over it. I take it as two doubles and it works well. My concern is the Truck isn't settling as fast as I'd like it too. It's bouncy down the straight and around these tight corners it's not settling down to get into the next corner.
5Likes
