Like Tree5Likes
SC10 4x4 Thread
Old 10-12-2011 | 11:33 PM
  #8551
CoyoteSlash's Avatar
I was kind of wondering like the other two have asked...
Craig's talking about the pinned rear, pics included. Not really a question there from you guys. (I hope)
- But a couple of you are also saying a "pinned front shaft" :IE- 'Wtf you talkin' bout' willis?'
Originally Posted by BulldogSRT
What size pin are you guys using to pin the slipper? Would a wheel hex pin be strong enough or does it need to be a larger diameter?
BulldogSRT
Craig (I believe?) was saying using a Traxxas hinge pin. Hardened steel and thicker. The hex pin will be too short and dinky.
CoyoteSlash is offline
Old 10-12-2011 | 11:34 PM
  #8552
Suspended
has the RTR version came out yet if so what yours thoughts on it
zenbonzakura is offline
Old 10-12-2011 | 11:39 PM
  #8553
You can see on Tower Hobbies that it isn't due out until Mid November.
Old 10-13-2011 | 12:09 AM
  #8554
BLbound's Avatar
Maybe some entrepenuering (misspelled) person could offer to drill & pin the rear lay shaft & slipper hub for a small fee?? MTK maybe? I personally don't have the equipment to do it, but I wouldn't mind sending a layshaft and a slipper hub to be pinned...what do you guys think?
BLbound is offline
Old 10-13-2011 | 12:14 AM
  #8555
I'd be willing to do it for you, just sending it to me, as a favor. But I haven't even done the modification myself "yet". I have all the equipment (drill press, blocks, and vice) to do it properly. I just don't think i'm the first choice. If there isn't another who offers or someone who spurs your confidence to do it yourself, send me a PM.
Old 10-13-2011 | 12:38 AM
  #8556
murky123's Avatar
Originally Posted by jpure009
On a tight indoor Clay/blue groove track, flat, med/high traction, with a few large jumps...
What does every1 think about clicker locked or not??...regular decoupled slipper
I have been running it locked, i know most people racing are not running it locked......I figured i would run it locked& maybe try unlocked eventually....
I have heard locked clicker, runs the belt down more, then unlocked...
any1 thx
I love the clicker unlocked. I can point an shoot at the apex of a tight turn and let the rear of the truck slide around ( very controlable )
You loose some on the braking ( because it only breakes on the rear )
you have to watch your jumps. it is a bit harder to get the nose down because of the front freewheeling off power and under breaking
Im not saying you will run your laps faster, but it is a very nice way of driving this truck. I really like it.
very smooth, non agressive way of driving
( note : i dont have to compete the losi's that much as you USA guys )
most trucks here are AE / durango . just 1 fast guy with a losi, I just let him go.
murky123 is offline
Old 10-13-2011 | 12:54 AM
  #8557
JRRobiso's Avatar
Default My Finished SC10 4x4
Just sharing some pics of my SC10 4x4 project. Pretty much stock. Only items upgraded are the following:
Garodisc pads
ST Racing alum steering bellcrank system
ST Racing alum belt tensioner pullies
Alum servo horn
AKA Enduro Soft with red inserts
JConcepts Hazard 3mm offset wheels
Blue alum lock nuts (4mm/3mm).......
Attached Thumbnails SC10 4x4 Thread-dsc01093-640x480-.jpg   SC10 4x4 Thread-dsc01094-640x480-.jpg   SC10 4x4 Thread-dsc01095-640x480-.jpg   SC10 4x4 Thread-dsc01098-640x480-.jpg
JRRobiso is offline
Old 10-13-2011 | 12:56 AM
  #8558
JRRobiso's Avatar
Default My Finished SC10 4x4 - Part 2
Other pics....
Attached Thumbnails SC10 4x4 Thread-dsc01100-640x480-.jpg   SC10 4x4 Thread-dsc01102-640x480-.jpg   SC10 4x4 Thread-dsc01105-640x480-.jpg   SC10 4x4 Thread-dsc01107-640x480-.jpg
JRRobiso is offline
Old 10-13-2011 | 12:59 AM
  #8559
Originally Posted by murky123
[B]just 1 fast guy with a losi, I just let him go.
We just can't let that go.
Old 10-13-2011 | 02:01 AM
  #8560
BLbound's Avatar
Originally Posted by JRRobiso
Other pics....
Looks good...congrats!!
BLbound is offline
Old 10-13-2011 | 02:51 AM
  #8561
Henry#40's Avatar
To those that have built shocks with 1 std o-ring,did you put anything in place of the missing o-ring or just leave it bare?
I have trackstar 0-rings coming but won't have them for the weekend.
Henry#40 is offline
Old 10-13-2011 | 04:09 AM
  #8562
Eli's Avatar
Eli
I left it bare, just one x-ring on bottom. You'll like trackstar o-rings
Eli is offline
Old 10-13-2011 | 05:42 AM
  #8563
1Fastpede's Avatar
Originally Posted by MantisWorx
to my understanding the heavy dif fluid and 4mm RC shims was to slow down the steering. today i dropped the shims down to 2mm and it felt much better. so i think i am going to remove them all and drop front fluid to see what happens, may work may not but someone has to try it
The diff fluid was to slow down steering but the shims I never thought of for slowing down steering. your lowering roll center by raising them which should INCREASE bite. Taking them out will Cause Push.
I know with my truck moving the front Inner ball stud to the inside gave me more on power steering during corner and exit.
1Fastpede is offline
Old 10-13-2011 | 06:19 AM
  #8564
MantisWorx's Avatar
this is probably going to start a war but here is what i noticed with the RC shims (roll center) lowering the shims gave me more initial bite but less mid and exit steering raising them worked the opposite. is that not the effect you are getting? even yesterday while testing this is what i did, my quickest times were when i removed the shims and went from 4mm to 2mm. i get the same effect in TC.
Henry i used green slime with a loose O ring in the bottom slot and they are perfect!
MantisWorx is offline
Old 10-13-2011 | 06:32 AM
  #8565
1Fastpede's Avatar
No war. this is how we figure these trucks out.
you said "lowering the shims gave me more initial bite but less mid and exit steering... raising them worked the opposite"
What confused me is earlier in the thread you stated you needed more exit steering. but here your saying lowering the shims takes the exit away..but yet you got faster.
I haven't noticed a big change when raising or lowering. the exit steering i gained was when i moved the ball stud from the outside to the inside location on the tower. The general rule is that less = more push on exit.
If you got faster with less shims. then I need to try it out. I'm currently at 4mm front and rear. which was 2 or 3mm less than what Kinwald was running.
