Like Tree5Likes
SC10 4x4 Thread
Old 10-12-2011 | 09:27 PM
  #8536
jpure009's Avatar
Originally Posted by Krio
The shock collars are the only way anyone should be setting their ride height. If you don't want to because the truck starts bottoming out go to a stiffer spring and oil combo and then lower the collars.
I am running the yellow F/R with 35wt all around &
RCSHOX 2stage all around...I'm at about 30mm F/R=ride height.
I was trying to get to 28mm, but i'd prefer to keep the setup as is.
THX
jpure009 is offline
Old 10-12-2011 | 09:29 PM
  #8537
THX
Are your shock collars bottomed out at the top of the shock so you can't lower it any more? If that's the case there really isn't a "right" way to go about lowering the ride height.
Krio is offline
Old 10-12-2011 | 09:35 PM
  #8538
jpure009's Avatar
Default Garolite pads
Originally Posted by CraigMBA
Once you pin the front drive belt, I'm not a big fan of mixing pads since the slipper doesn't slip independently F/R anymore.
I would use the same pads across the slipper with the pin modification (no matter if you were using the basket or not). Once you get it adjusted properly, I'd expect the forward bite to be the same no matter which one you choose. IMO only difference between them is going to be how long they last before you have to do maintenance on them.
If users are going to leave the slipper decoupled, I'm certain everyone will find some magic cocktail of slipper pads that work best for them (we have a couple hundred pages of just that in this thread).
i asked Marcus if i could run the(RCSHOX) Garolite slipper on the outside and HD pad inner... He said that's not a good idea, if i run the RCSHOX pads outer& HD pad inner, they might lock up...
Are u guys speaking of a different kind of Garolite pad???
So i was going 2morow to the track, and had the RCSHOX pad inner&outer..
THX
jpure009 is offline
Old 10-12-2011 | 09:37 PM
  #8539
CraigMBA's Avatar
Originally Posted by Divey
Can someone explain to me how to weigh the truck for balance from side to side and front to back without a scale. I have moved the battery over on the motor side due to fitment issues and now it's a little heavier on that side. I just got some losi stick weights today but I am unsure how to weigh it. Anyone have any ideas.
Terry
Search this thread on scales, find my thread, spend $30, buy some, be prepared to be the fastest guy at your track who has them.
Questions?
CraigMBA is offline
Old 10-12-2011 | 09:39 PM
  #8540
jpure009's Avatar
Default ride height
No, the collars are not all the way to the top....
At the track i'm at, the jumps are violent....So I have the collars
down about 5mm in front & 7mm in rear.....
So, if i go to 3mm front & 5mm rear, I mite be able to achieve a 2mm
lower ride height??
Maybe with the jumps being so Violent, i'm better at 30mm ride height?
thx
jpure009 is offline
Old 10-12-2011 | 09:41 PM
  #8541
CraigMBA's Avatar
THX
If you pinned it, I think that's fine. If you didn't, you're on your own and good luck.
CraigMBA is offline
Old 10-12-2011 | 09:44 PM
  #8542
CraigMBA's Avatar
Do a search on this thread, spend the $30 it will take to get the scales. Seriously.
CraigMBA is offline
Old 10-12-2011 | 09:48 PM
  #8543
CraigMBA's Avatar
Originally Posted by Sofa King
string through the underbody mounts will get you left to right
EXCEPT you can have the L/R AFU and still have the F/R % correct. I keep trying to tell you guys, the L/R balance isn't that important - its the FR splits and the cross weight, and even there 50/50 isn't right.....
CraigMBA is offline
Old 10-12-2011 | 09:52 PM
  #8544
CraigMBA's Avatar
Originally Posted by sugs
Anyone running the pinned shaft, would be nice to know if you are using the clicker or not, and what difference it now makes.
The only time you are going to use the clicker or a one way is on asphalt and slicks, or carpet and foams, or astroturf and ?????? they run for tires. On dirt if you have to slow down...
No way!
CraigMBA is offline
Old 10-12-2011 | 09:58 PM
  #8545
lower ride height??
thx
The shock collars are the correct way (and should be the only way) to set the ride height of the car while its on the ground. If the jumps are large, ride height doesn't affect landing much if you are only varying the ride height by a couple millimeters as the shocks fully extend in the air regardless and the oil/pistons should take the brunt of the landing; not the springs. It doesn't hurt to lower it, try it, and go back if it doesn't feel right.
Krio is offline
Old 10-12-2011 | 10:23 PM
  #8546
So, if 50/50 isn't right... WHAT is?
Sofa King is offline
Old 10-12-2011 | 10:33 PM
  #8547
murky123's Avatar
Id like to know also.
are the guys that pinned the shaft and are running clicker? how is it?
murky123 is offline
Old 10-12-2011 | 11:13 PM
  #8548
jpure009's Avatar
no, i'm not going to pin it for now anyways....just regular slipper....
Craig,
So, what r u saying, i should'nt run the Garolite pads inner&outer???
just outer?
just inner??
Both inner&outer makes sense, and that's what Marcus said.?.
As long as nothing is going to break, i can try inner&outer and if it doesn' feel right, switch....Isn't that what u meant by a "cocktail" mixture with the regular slipper?? Hdpad/stock pad/garolite pad mixture between inner& outer of the decoupled slipper??
thx
jpure009 is offline
Old 10-12-2011 | 11:18 PM
  #8549
jpure009's Avatar
Questions?? clicker
On a tight indoor Clay/blue groove track, flat, med/high traction, with a few large jumps...
What does every1 think about clicker locked or not??...regular decoupled slipper
I have been running it locked, i know most people racing are not running it locked......I figured i would run it locked& maybe try unlocked eventually....
I have heard locked clicker, runs the belt down more, then unlocked...
any1 thx
jpure009 is offline
Old 10-12-2011 | 11:27 PM
  #8550
What size pin are you guys using to pin the slipper? Would a wheel hex pin be strong enough or does it need to be a larger diameter?
BulldogSRT
BulldogSRT is offline
