Like Tree5Likes
SC10 4x4 Thread
Old 10-31-2011 | 07:07 PM
  #9901
pvalenti's Avatar
Originally Posted by rickybobbyxxx
Yea checked all that,brake is at 60% with tekin 4 pole, but it seams to do it as soon as i hit even the smallest bump, it literally wont go a full lap without the belt flipping over
Well it's rather obvious so you've probably considered this already. But maybe you should try another belt?
Short of that one...maybe try taking it to your Local Hobby Shop and have them give it the 'once over'...I've seen your posts and I feel your pain...but I really didn't have anything 'helpful' to say that the rest of the guys here haven't said or suggested to you.
pvalenti is offline
Old 10-31-2011 | 07:55 PM
  #9902
Thanks for input guys, think im gonna try calling associated tommor, maby they have an idea, this is sooooo frustrating, finally got my pin mod done, and now this started happening
rickybobbyxxx is offline
Old 10-31-2011 | 08:01 PM
  #9903
Mizchief's Avatar
Hey guys, hate to keep asking but my truck wont make it one lap without the belt twisting around and getting jammed in the front clicker, tensioners seem fine, everything looks strait on the bench but as soon as i put it on the track it happens,btw it starting doing this after i intalled a new clicker, it seems fine though
Try posting some pics of your setup with the belt cover off with close ups of both ends.
Speaking of which, have you tried running it a a few laps with the cover completely removed to see if it's getting snagged somewhere?
Are you hitting hard on the nose when landing with power applied like when trying to get the nose to raise up right before face planting into the landing of a double? I could see how that could flex your chassis and loosen the belt as seen a few pages ago, and if your on the gas when that happens the belt might be able to come off the guides.
I would try setting the tensionors as tight as they will go without locking up the motor and see if you can get a few laps in, may help you determine if that is the issue.
Mizchief is offline
Old 10-31-2011 | 08:05 PM
  #9904
This is just a shot in the dark. But when I did my pin mod. My pin is not perfectly perpindicular to the shaft. So I have to make sure to put slipper hub in the right way.
So maybe yours is the same. To were if not in the right way there is room for the belt drive hub to slide out.
hickwheeler is offline
Old 10-31-2011 | 08:07 PM
  #9905
Mizchief's Avatar
Yea, based on that I bet it is landing hard with power that's causing it. The pin mod basically locks the two slipper plates together but lets the spur spin between them, so your losing that extra slip on the belt side so hard breaking and acceleration could cause the belt to stretch instead of slip, then add a little bit of frame flex into the mix and it might be pushing it over the edge, specially if your slipper is tight and your belt is on the loose side.
PS: I'm a bit of an RC car noob, but i'm basically a professorial problem solver (programmer) so I'm just trying to find logical explanations based on the info given, I don't mean to slam the pin mod or anything like that.
Mizchief is offline
Old 10-31-2011 | 08:12 PM
  #9906
Yea havnt installed pin mod yet,and yes first time it flipped over it was coming off a pretty good set of doubles, after that though all it takes is one little bump for it to happen, u dont even have to touch the brakes
Old 10-31-2011 | 11:45 PM
  #9907
Hi everyone. So I just got my sc10 4x4 last week and ran it for the first time at the track. There are definitely some tweaks I need to make, but one thing I was having a major problem with was TRACTION ROLLING. It was doing it in the sweeper and two different hairpins. I have sway bars which I know should help but they weren't doing much. Are there any suggestions you have to help this?? Thanks
tjbgtv8 is offline
Old 10-31-2011 | 11:51 PM
  #9908
CoyoteSlash's Avatar
Less Traction.
CoyoteSlash is offline
Old 11-01-2011 | 03:31 AM
  #9909
pvalenti's Avatar
Lightbulb
Yellow springs in front, 32.5wt front/27.5wt rear, middle shock tower (front and rear), outter arm (front and rear), add 4mm spacer (made from 1mm suspension washers) under the inner camber link in front and 2mm in rear, set ride height to 22/24 (front/rear).
The most important of those being the spacers under the inner camber links...it drops the roll center of the truck, as does lowering the ride height. The heavier front springs stiffens up the suspension a bit and will help also with roll-over a bit.
pvalenti is offline
Old 11-01-2011 | 05:13 AM
  #9910
symmetricon's Avatar
Ok, sorry for being late, but here is my setup. i also aded 4oz to the truck in adition to the weight I used to balance it. I put 1oz in all 4 corners.
Crap, I also added 2mm of shim undr the front camber linkage. somehow I didnt write that down. Also, I am running the +3mm hazard rims
Here is how I added the weight.
symmetricon is offline
Old 11-01-2011 | 05:17 AM
  #9911
Originally Posted by MantisWorx
what about the Losi guys running "super wide" offset wheels, that needs to be stopped too, half the tire hangs out of the body. a simple "tires must be inside the body " rule needs to be enforced.
100%agreed. The shananigans need to stop.
Old 11-01-2011 | 05:25 AM
  #9912
BlueGlowBoy's Avatar
+10 on lowering the roll center. As soon as I did this, I stopped traction rolling with the exact same setup I was running before. Rather than lowering it 4mm/2mm, I had lowered mine 3mm/3mm and it is working for me.
BlueGlowBoy is offline
Old 11-01-2011 | 05:26 AM
  #9913
Where do you live? Maybe you live close to someone who can help trouble shooting the problem.
Old 11-01-2011 | 06:03 AM
  #9914
fastrc64's Avatar
here is something that can happen that can cause the belt to flip make sure that their is nothing in the pulleys front and rear , check them for damage if one is chunked it can cause the belt to flip under stress and high RPM
if you don't find a problem there i would disassemble it and make sure it was assembled correctly
fastrc64 is offline
Old 11-01-2011 | 06:12 AM
  #9915
MantisWorx's Avatar
i know this sounds dumb but i had the same problem and it ended up being the chassis screws had backed out slightly. after tightening them all down the belt has not twisted or come off since.
MantisWorx is offline
