Team Magic E4 Thread
#1546
The Losi only has two belts. Many things can effect the motor temp when running the recommended FDR, track size, driving style, speedo setup, etc.
#1549
I'm gearing my E4JS by temp. If its too hot, I drop the pinion down a couple teeth. Run and check temps again until I hit the acceptable range. I've found so far I run pretty much the same lap times in TA trim with my SS21.5 from 4.2 up to 4.6 FDR. At 4.6 my motor is finally coming off around 145* or so. At 4.2 it was 175*. I'm going to try 4.8 for giggles. I would imagine that as long as I'm not hitting the RPM limit on the motor, I should see no decrease in lap times. I should also see more punch out of the corners. I haven't proven that to myself, but it sure sounds good.
#1550
hey guys just got back from a two day race here in tucson az the southwest indoor grand prix. I purchased the original e4 and this was the first time seeing the carpet, been runnin on asphalt. all i can saw was the car was dialed. i started with one of marcos j setup and went from there. the track was a pretty technical track and the car transitioned really well. i also switched from the tc5, but out of the box with minor adjustments the e4 was bomb.
At the end of the weekend i ended up tq plus a win in stock rubber tire. The drive train is pretty tight but i dont think it hurt the performance at all. only negative thing was i broke a rear cvd? didnt hit anything just going down the backstraight and then the next turn it didnt have any rip? i didnt have that as a spare so i used a xray dogbone. If anyone wants the setup shoot me a pm.
Thanks again wolf for supporting a good car and having good customer suopport
#1551
Hey marcos you are down in florida right? are you going to snowbirds, i was looking into getting a foam car and running 13.5 rubber and foam, will you be there or will there be another team magic driver there? either way i will head that way and see what i can do with the cars. Gotta save up for a foam car now. Later guys
#1552
Does anyone use the Kfactory sidemount fan for cooling and does it do an efficient job???
Also what set of springs should I get??? There are three sets, or are they all different. I will primarily be running asphalt,rubber tires. Thanks!!!
#1553
sup flounder,
blake here .. i will be switching to tm here in a few weeks .. i bought the set of springs 8pack from leim this past sat.. i will let you know what colors to get and use .. the set is only 26 and some change why dont you come down to easley sat .. where going to have a good crowd.. 7 or 8 in 13.5 and vintage
#1554
Check out wolfhobbies E4 FS/RS on sale for $349.99.
#1555
That's funny! I would love too but I have somewhere I have got to be Saturday night at 5pm and that would not allow much racing with the two hour drive for me. I have really go the bug though after this past weekend with the new car.
I hope you like it when you get it, I know you will! Like you need any help going faster!
#1558
The car handles nice at the Track and I was turning consistant 13 second laps with my 13.5 set-up. Do you have the Tekin Hotwire? I think the new software 1.89 is out and you can download it. Set it on sensored only and raise the boost up to 80 to start. I think you'll like the response. If you don't have a hotwire then try to go there when Dave Arnold is there on Saturday.
#1559
No Wolf does not sponsor me and unfortunately I won’t be at the birds this year.
#1560
i am trying to figure out if there will be any people there running the e4 or will it be just me? see what i am gonna have to do for parts since if i break there i will have a tough time rigging something. wease any idea if anyone will be there running the car? thanks guys
