Team Magic E4 Thread >
Old 10-26-2008 | 10:24 AM
  #1396
nocif13's Avatar
what are the parts consistent (compatible) with the E4 SEDAN AND RS E4?
thank
olivier
nocif13 is offline
Old 10-26-2008 | 12:09 PM
  #1397
hello, to balance the chassis using one lipo of 3800 or 4000, how many grams have you ballast the chassis and in which side?, thanks.
ysyracing is offline
Old 10-26-2008 | 08:31 PM
  #1398
Try in the middle of the chassis over the battery for the best balance.
AreCee is offline
Old 10-27-2008 | 06:52 AM
  #1399
tenpins77's Avatar
Hey, anyone have any gearing info for a 13.5 and a 5.5 turn motor?
Also, i run on a high grip asphalt and carpet track, running only rubber? hows setup out of the box?
Also, i cant seem to find a manual to download, i only found one, but it was very brieif, and didn't really show much on how to put it together? Hows the manual that comes with the car?
tim,
tenpins77 is offline
Old 10-27-2008 | 10:25 AM
  #1400
tim,
I just raced my E4 for the first time yesterday and the out of box setup was very good, a bit soft but very controlable. I didn't have any springs to tune with and the air temperature was dropping fast, from 60F to 40F. I had Sorex 24R with Tamiya soft inserts and it ran well. CS27s worked well when it was warmer. Camber was -1/-2 F/R, r.toe 2.5, f.toe 0, ride height 5.5f/6r, 30wt oil all around, 0 droop.
Gearing: I use a 4.5 FDR with the 13.5 (96 spur/44 pinion). For the 5.5 I would start at around a 7 FDR and gear up from there.
The manual uses CAD drawings and the steps are numbered for execution. There are no set up tips, hints or suggestions. I found that this was one of the easiest cars I ever built, everything fit pefectly (with the exception of too much thread lock on a couple set screws).
AreCee is offline
Old 10-27-2008 | 10:43 AM
  #1401
tenpins77's Avatar
Thanks for the help ARECEE
Whats the FDR for the car?
Also, whats price ticket?
tim
____________
Tim Stuart
Web Developer
TeamTrinity.com
Old 10-27-2008 | 04:43 PM
  #1402
tim
____________
Tim Stuart
Web Developer
TeamTrinity.com
The internal drive ratio is 1.888 for the foam spec and 2.059 for the rubber spec and are both priced at $409.95 at http://www.wolfhobbies.com/
The Wease is offline
Old 10-27-2008 | 10:25 PM
  #1403
Anyone use Tamiya shocks on their E4? Curious on how the stock E4 shocks compare to the Tamiya 415/416 shocks.
cpatel529 is offline
Old 10-28-2008 | 11:22 AM
  #1404
nocif13's Avatar
hi
yes i use a tamiya trf fluorine shocks on their E4 sedan
http://1.bp.blogspot.com/_HnkkKN44vA...h/P8150527.JPG
nocif13 is offline
Old 10-29-2008 | 05:20 PM
  #1405
liljohn1064's Avatar
Originally Posted by Marcos.J
E4 springs
1.2mm =10lbs
1.3mm=13lbs
1.4mm=17lbs
1.5mm=20lbs
1.6mm=26lbs
1.7mm=31lbs
1.8mm=41lbs
1.9mm=51lbs
you can run any AE spring just use the bottom shock collar for the tc5 so you can get the correct ride height.
Perfect advice! I also trimmed the lower shoulder so the pieces met at the top and bottom of the spring retainer instead of just at the bottom. It helped gives me all extra space I needed.
liljohn1064 is offline
Old 10-31-2008 | 11:29 AM
  #1406
adrictan's Avatar
I'm thinking of getting a E4RS. Just want ask:
Can I use the front Spool(503234) that comes with the kit and put it in the rear and buy a separate front one-way(503131) and use it for the front? It's to be used as a drift car.
adrictan is offline
Old 10-31-2008 | 11:34 AM
  #1407
Marcos.J's Avatar
Super Moderator
the rear diff pulley is on the center, the spool is off to the side , the belts will not line up in the rear. The best thing you can do is to make the rear diff a slipper spool.
Marcos.J is offline
Old 10-31-2008 | 11:46 AM
  #1408
adrictan's Avatar
My apologies but mind explaining what is a Slipper Spool?
I basically wna tot set it up like my other cars. Front to be running One-way and the rear to be on solid axle/ spool. Team Magic don't manufacture these items?
adrictan is offline
Old 10-31-2008 | 12:00 PM
  #1409
Marcos.J's Avatar
Super Moderator
sorry , in the rear diff take out the diff balls out and glue some header card( business card) to the diff rings then cut them to the same diameter as the diff rings, then tighten the rear diff and you should have a rear spool.
Marcos.J is offline
Old 11-01-2008 | 12:50 AM
  #1410
Just ordered my e4 tonight, cant wait for it to come in i have been contemplating it for some time. First one in my area with it(az) so lets see what it can do!!!
WEEZY is offline
