Team Magic E4 Thread
#2151
Everything about that car is CG.
No ,lol not cover girl!
Just figured it would be that much lower with the wires routed like that.
I didn't feel there was enough room in the right side by the pinion for the blue one to go there too. The sensor wires are in there as well. This chassis is screaming for a Novak Ballistic motor !!! I ran it today only once and after the race Wednesday night but what a car.
2deg camber
35wt associated oil
K factory #21 front and #26 rear springs.
direct drive spool. Blue Jaco Prism premounts.
The word for today is BALANCE.
Please make a note of it.
My 416 is getting converted to VTA
2deg camber
35wt associated oil
#2153
Very very very well mannered car. very predictable and smooth as glass. No wonder Dave won ! I love this car ..... Thanks Wolf for fixing what ailed a great car. I bet Team Magic is miffed about your version being WAY better than the last one I got.
#2154
Do you guys have good setup of the following..? After almost 1.5 years collecting dust, I think I need to open up all 3 NIB E4RS E4FS and E4 whatever S that is and run outdoor and some indoor foams...
Any good rubber tires outdoor parking lot racing 13.5/17.5 (possible RCGT class)?
Any good rubber tires indoor carpet racing 13.5/17.5?
Any good foam tires indoor carpet racing 13.5/17.5?
Thanks....
Thanks....
#2155
[QUOTE=Solara;5896827]Do you guys have good setup of the following..? After almost 1.5 years collecting dust, I think I need to open up all 3 NIB E4RS E4FS and E4 whatever S that is and run outdoor and some indoor foams...
35 associated oil
17lb front /11lb rear springs
5.25mm front/ 5.5mm rear ride hight
2 deg camber f/r
1 deg toe out front / 2.5 toe in rear
Front spool direct drive
#4 hole top shock mount, outside hole bottom f/r
all roll center mounts #2 hole i/o, 3mm under inner front
1.2mm sway bars f/r
Use double steering mechanism and rear hole on steering blocks.
I LOVE IT!
35 associated oil
2 deg camber f/r
1.2mm sway bars f/r
I LOVE IT!
#2156
[QUOTE=John St.Amant;5897014]
Awesome...thanks.
Now...anyone has one for OUTDOOR parking lot..? Prefer 13.5 kinda speed...thanks
35 associated oil
2 deg camber f/r
1.2mm sway bars f/r
I LOVE IT!
35 associated oil
2 deg camber f/r
1.2mm sway bars f/r
I LOVE IT!
#2159
Thanks....
Thanks....
http://www.petitrc.com/reglages/team...ly20090426.pdf
or
http://www.petitrc.com/reglages/team...ie20090329.pdf
#2160
[QUOTE=John St.Amant;5897219]
I thought in this world, only Tamiya TA05R/IFS-R is the only car that can do 1 setup and use it for indoor carpet, outdoor parking lot and foams without doing setup change...LOL
Thanks...
Thanks for the setup, you sure that is not your typical "RAIN" setup right..? We American here cannot afford to fix wet speedo, wet lipo and wet brushless motor LOL
Thanks...
