Team Magic E4 Thread >
Old 02-12-2010 | 08:30 AM
  #3046
Pro10noob's Avatar
I bought the Wolfhobbies alloy upgrade set and have to say that a lot of slop is gone.http://www.wolfhobbies.com/product.c...7&product=8351
The only bit of slop i have is on the outside of the axle where the wheels go.
This is due to the 2 piece set of the outside of the axle.
At the moment i ordered the steel hubs from the E4JS and some clamb on wheel hexes to get rid of all the slop there..
I am also waiting on a set of red shocks so i can complete my E4 to a red racing monster.
If i have them fitted i will post some pics up as the car looks rather nice with all those red parts
cheers Roy
Originally Posted by blis
Isaac.. do the Alu hubs remove the slop?
Pro10noob is offline
Old 02-12-2010 | 08:46 AM
  #3047
Isaac's Avatar
Yes they did for the most part although right now the left hub carrier has a "little" slop just because of wear. I haven't really broken anything except dog bones.
Isaac is offline
Old 02-12-2010 | 08:47 AM
  #3048
Isaac's Avatar
Originally Posted by Born2Run
I haven't got yet my TM RS'09 but i read here that you cannot fit all the BL motors without some dremel work on the belt tensioner.Why this?Because of the motors lenght or something else?Could someone help me please to get the picture?
Yes because of the motor length. Novak Ballistic motors work without any modifications.
Isaac is offline
Old 02-12-2010 | 09:24 AM
  #3049
wyd's Avatar
wyd
Tech Legend
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
cheers Roy
Cool. You will have to post some pics when you have it all done.
wyd is offline
Old 02-12-2010 | 09:26 AM
  #3050
Pro10noob's Avatar
Not only the lenght of the motor but also the shape.
The LRP X11 motors fit perfectly without the use of a dremel.
It is because of the backside shape of the motor.
If it is tapered it fits ok,if it is like the Tekin or GM motors with a 90 degrees backside,you have to dremel a bit on the side belt tensioner and the left bulkhead to get anough room to play with the gears.
cheers Roy
Old 02-12-2010 | 09:28 AM
  #3051
buffalobill989's Avatar
Originally Posted by Isaac
I suggest front steel universals, purple and pink springs, set of shims from www.wolfhobbies.com in 1 and 2 mm sizes, get the aluminum single bell crank (steering), 110 spur for more brushless gearing options and that's all I can think of now. I have all aluminum hubs and steering knuckles.
whats the part no for the alum single arm steering? that looks like something i want to add. same goes for the 2 red upgrade kits
buffalobill989 is offline
Old 02-12-2010 | 09:31 AM
  #3052
Isaac's Avatar
http://www.wolfhobbies.com/product.c...3&product=9400
Isaac is offline
Old 02-12-2010 | 09:32 AM
  #3053
thanks. i didnt look into the kfactory stuff.
Old 02-12-2010 | 09:36 AM
  #3054
is that all i need or do i need a single bell crank conversion. ive got an older e4 that has the dual bell crank. thanks for the help
Old 02-12-2010 | 09:38 AM
  #3055
Isaac's Avatar
Not sure about the older chassis and all that may be needed. I can't answer that but call up Wolf Hobbies (or email) and they will let you know.
Isaac is offline
Old 02-12-2010 | 09:42 AM
  #3056
thanks ill shoot him an email
looks like its time to place an order
  #3057
Pro10noob's Avatar
Sneak preview
cheers Roy
Sorry about the size tho
Old 02-12-2010 | 09:51 AM
  #3058
blis's Avatar
Default E4 Original
To use this on an E4 original you may need longer steering turnbuckles.. we did.
blis is offline
Old 02-12-2010 | 12:36 PM
  #3059
Born2Run's Avatar
cheers Roy
Roy
Do you think i'll have some issue with this motor?
Born2Run is offline
Old 02-12-2010 | 12:46 PM
  #3060
Isaac's Avatar
You *may* not because of the slanted end.
Isaac is offline
