Team Magic E4 Thread >
Old 12-04-2008 | 02:20 PM
  #1516
Tomradio's Avatar
Nice photos, thanks for the info.
Tomradio is offline
Old 12-04-2008 | 10:00 PM
  #1517
liljohn1064's Avatar
Very important note. To anyone using the E4JS chassis and needs it to fit a 10" wheelbase body, such as the Vintage Trans Am HPI bodies. You will need to trim 3 mm off the front of the rear a-arm and put 3 mm worth of spacers on the back to slide the whole arm forward. You will also need to move both carrier shims to the rear of the carrier to move it towards the front end. This is 3.5 mm worth of movement.
HPI body wheelbase 255 mm.
E4JS wheelbase 259 mm.
My rear wheels are perfectly centered and my fronts are ever so slightly forward in the wheel well. Hope this helps too.
liljohn1064 is offline
Old 12-05-2008 | 08:37 AM
  #1518
Anyone have a Good Carpet 17.5/Stock Setup.
Working with a guy at my local track with the car.
Dave
dragracer72nova is offline
Old 12-05-2008 | 08:44 AM
  #1519
Dave
Dave, I'd ignore that guy.
Old 12-05-2008 | 08:52 AM
  #1520
HHHMMM,
I do have time today to make my car into T/A specs
Dave
Old 12-05-2008 | 09:36 AM
  #1521
HHHMMM,
Dave
And put your 415 into stock form instead? Might be a good idea.
Old 12-05-2008 | 04:24 PM
  #1522
Hoggy's Avatar
hey all, i just picked up a E4 FS C/1 and am planning to race it in Modified with Lipo and a 4.5 brushless motor on medium grip ashphalt
is there any upgrades that i should purchase?
also where is a good starting point for set up. i will be usig team magic springs
thanks in advance.
Hoggy is offline
Old 12-05-2008 | 04:45 PM
  #1523
thanks in advance.
Aluminum pullies and Kfactory belts
The Wease is offline
Old 12-05-2008 | 06:12 PM
  #1524
Hoggy's Avatar
Ok, thanks
Hoggy is offline
Old 12-05-2008 | 08:37 PM
  #1525
Tomradio's Avatar
thanks in advance.
I would get the aluminum rear hubs (1.5 degrees of toe in) it will give you more options for your rear toe especially on a medium grip track. Also the aluminum upper bulkheads f/r, the plastic bulkheads may flex when running mod. And like The Wease suggested you can't go wrong with the kfactory belts. Enjoy the new ride……
Tomradio is offline
Old 12-06-2008 | 02:56 AM
  #1526
lore's Avatar
Hi All, I just bought an E4RS, i was wondering which brand of brushless can I use?
I have a Teking 10.5 but looks like i can't fit in.
Any suggestion are greatly welcome.
lore is offline
Old 12-06-2008 | 07:20 AM
  #1527
Tomradio's Avatar
The Novaks fit without any modifications. With some dremel work you can get your Tekin to fit.
Tomradio is offline
Old 12-06-2008 | 01:50 PM
  #1528
getpip's Avatar
Hey guys
I am considering an E4RS as a replacement for a TC5.
I will be racing mostly stock 13.5bl rubber on carpet.
I am wondering if the 3 belt system will be free enough for stock or if it will suck up too much power.
Also I read that not all motors fit because of the length of the can.. whats the longest can that fits.
Ant other good and bad points of note?
Pip
getpip is offline
  #1529
getpip's Avatar
Default E4RS
getpip is offline
Old 12-06-2008 | 03:35 PM
  #1530
Originally Posted by getpip
Any extra drag from the third belt is negligible.
Novak, LRP, SP, etc.
AreCee is offline
