Team Magic E4 Thread >
Old 11-17-2008 | 09:34 PM
  #1486
Hey guys ran the e4 last weekend for the first time. Ran asphalt outdoor med grip, big sweeping track. I started with the kit setup and it felt soft and the backend wanted to kick out. so i put xray springs on stiffen it up a little. And added 1mm shim under the rear turnbuckle on the bulkhead to get some more traction. It somehow got crazy steering with the stiffer springs on the front. i am also running a r9 body. later guys
WEEZY is offline
Old 11-17-2008 | 10:56 PM
  #1487
rambolin's Avatar
Default E4 and top speed
Dear Socko, AreCee, rezenclowd3 and BritishMenace
RE: <<I am new to the E4 and I can not get the required top speed out of this car.>>
Thanks for your help.
I will not know until after the coming weekend if swapping Esc and Motor will do the trick.
The same battery was used afterwards in a different car and made it to 2nd over all.
I took the belts out and all seems to run very easy without the belts.
Maybe they should put some chicane on the long straight !
I will let you know in a week’s time...
Regards
rambolin is offline
Old 11-17-2008 | 11:56 PM
  #1488
PutAwayWet's Avatar
You fans of this car might be interested in some disinterested observations of this car's performance this past weekend at the Northwest Indoor Championship at Timezone 2.
Two chassis, one 13.5 rubber, and the other Mod foam, driven by a sponsored guy from out here. He squared off against a really fast and well driven X-Ray in rubber, and an X-Ray and an Associated in foam. Full fields in both, mind you, but these were the guys at the sharp end. The Team Magic took down both classes.
I was particularly interested in the 13.5 rubber because the concern with the car has been the three belts and the presumed drivetrain drag. With mod one could always say that if there is more drag it's hard to tell given the insane power laid down. Not so in 13.5. But the car was superb, and didn't put the driver at any disadvantage. It looked quick and stable edge to edge through the infield, and consistent for five minutes. And believe me, these were good racers, and they were giving no quarter throughout quals and mains.
It's a car to consider. It might be my next sedan. And it's not all uglied up with lead everywhere. Right underneath the battery seems to get it done. It has some fussy parts, but the layout is sound, and drag didn't seem to be a factor.
Todd M.
SIR
PutAwayWet is offline
Old 11-18-2008 | 12:14 AM
  #1489
Korey Harbke's Avatar
I dont care what sedan you get, you just need to get one again!!!! LMAO
Korey Harbke is offline
Old 11-18-2008 | 01:34 PM
  #1490
Juanchoyo's Avatar
Opinions on the JS edition, I really like this car layout but im on a budget and planning to run 10.5 or 19T... Where do you get parts for these cars on Internet??? What are the hop ups i'd need to keep the JS version running well??
Thanks in advance guys
Juanchoyo is offline
Old 11-18-2008 | 02:53 PM
  #1491
track-attack15's Avatar
You can get parts for it at wolfhobbies.com.
track-attack15 is offline
Old 11-18-2008 | 07:17 PM
  #1492
Todd M.
SIR
Todd..... Daves 13.5 car has been gone through to free up the drive train . He/his car was 1 full second faster a lap than me/mine. He is using the Kfactory belts, aluminum pullies and I was running stock pullies and belts.
Mike
The Wease is offline
Old 11-18-2008 | 07:25 PM
  #1493
Originally Posted by pinkpanther
The deck brace i purchased must be for the original E4 and not The RS. I wonder where the brace on the car pictured a couple of pages back is from. I cant find anything on the KFactory website.
The Orion Vortex seems quite long as when is place it fouls on the chassis. At the front of the motor, although there is a bevel, one of the three screws fouls on the chassis restricting how you can orientate the motor. This is the same at the back of the motor where there is no bevel at all.
I have made a small bevel on the chassis around the cut out for the motor and i now have sufficient movement up/down and i can rotate the motor to some degree.
However, there is little front/rear play maybe 1-2mm and the motor sits towards the rear of the car meaning i cant install a heatsink as it will foul on the pulley.
I am now having to remove material from the side brace (where the side belt tensioner is attached) to allow more play. I haven't tried to mesh yet but I'm worried that with the motor being so restricted even with modifications that my gearing options will be more limited.
Ps, thanks for the link!
The aluminum upper deck mount #503111 - E4 Alum. Upper Deck Mount
will give you a little more room than the stock plastic deck mount
Old 11-18-2008 | 08:34 PM
  #1494
PutAwayWet's Avatar
Mike
That's good to know. Though the platform is actually new to you, no? You were running the Cyclone not more than a month ago. Is it possible you're still in the basic break-in period? Both the chassis and the driver. You hadn't even broken it yet, and that's just not like you
Thanks for the heads-up, though. I'm actually pretty interested in the car, despite my 1/12th scale zealotry.
Old 11-18-2008 | 11:31 PM
  #1495
t4m1y4niac's Avatar
Originally Posted by liljohn1064
I'm running Novak SS17.5s in both of mine for VTA.
What I did:
1. Take off the chassis stiffening brace.
2. Pull the sensor wire through the belt.
3. Install the motor. I had to massage it in due to the motor shaft, but it works.
4. Put the brace back on.
5. Tie wrap the sensor wires to the motor wires leaving enough loop to not rub the belts. It works nice, doesn't pinch any wires and the belts never touch the sensor wire.
This leaves me with about an 1/8" gap from the endbell to the chassis.
i've tried your tips...the BL motor can fit to motor mount but i cannot adjut the motor position to get the proper gear mesh...
and it seems team magic will not help me at all...they doesn't reply my e-mail.
t4m1y4niac is offline
Old 11-19-2008 | 04:54 AM
  #1496
I use a Novak 13.5 and a LRP 4.5 with no problems.
AreCee is offline
Old 11-19-2008 | 08:12 AM
  #1497
liljohn1064's Avatar
Here is the example for my 21.5 I now run.
94 40 1.08 2.35 4.84 1.69 42.86
94 41 1.09 2.29 4.72 1.73 43.93
94 42 1.09 2.24 4.61 1.77 45.00
94 43 1.10 2.19 4.50 1.81 46.07
94 44 1.11 2.14 4.40 1.86 47.15
94 45 1.12 2.09 4.30 1.90 48.22
94 46 1.13 2.04 4.21 1.94 49.29
Spur is the first column
Pinion is the second column
Center of spur to center of pinion distance in inches is the third column. For this car it needs to be between 1.00 and 1.25 inches or it won't work. (this is what your are fighting!)
Spur/Pinion Ratio is the 4th.
FDR is the 5th column. (based on the 2.0588 internal ratio)
Rollout in inches is the 6th. (based on a 2.6" or 66 mm tire)
Rollout in mm is the 7th.
liljohn1064 is offline
Old 11-19-2008 | 08:19 AM
  #1498
that's because the spur supplied with the kit is too large for most brushless applications for the higher turn motors. To get to the Novak FDRs you have to run really huge pinions and really small spurs.
Old 11-19-2008 | 08:24 AM
  #1499
and for the 17.5 specifically:
86 40 1.02 2.15 4.43 1.84 46.85
86 41 1.02 2.10 4.32 1.89 48.02
86 42 1.03 2.05 4.22 1.94 49.19
86 43 1.04 2.00 4.12 1.98 50.36
86 44 1.05 1.95 4.02 2.03 51.53
86 45 1.05 1.91 3.93 2.07 52.70
86 46 1.06 1.87 3.85 2.12 53.87
86 47 1.07 1.83 3.77 2.17 55.05
86 48 1.08 1.79 3.69 2.21 56.22
86 49 1.09 1.76 3.61 2.26 57.39
86 50 1.09 1.72 3.54 2.31 58.56
86 51 1.10 1.69 3.47 2.35 59.73
86 52 1.11 1.65 3.40 2.40 60.90
Novak recommends no lower than a 3.4 and up to 3.7.
You can get the 86 tooth spur and 52 tooth pinion from Precision Racing Systems.
Old 11-22-2008 | 03:06 AM
  #1500
Hello every one, I was just woundering if there is any one els out there running the E4 in stock ( J 540 motors)
TM Driver Bob is offline
