Team Magic E4 Thread >
Old 11-07-2008 | 04:08 PM
  #1456
blee's Avatar
Wink
Originally Posted by cvccsi
For those of you who own an E4..
I just got my E4FS. I find that there is some play on the front and rear diff (Diffs are in the car and moves left and right). Is this normal?
Thanks.
Of course not normal........ loose the screw of side plates and bulkhead, re-tighten the screw carefully and it would be fine.
blee is offline
Old 11-07-2008 | 04:11 PM
  #1457
Thank you.. I will give that a try.
cvccsi is offline
Old 11-08-2008 | 04:19 PM
  #1458
I tried reassemble the front and rear bulkhead but there was still left and right movement on the diffs. Ended up, I've used shim to stop the play. Anyone one who also used shim on the diffs?
cvccsi is offline
Old 11-08-2008 | 06:58 PM
  #1459
blee's Avatar
Exclamation
Is that right, I never have this problem.
I thought you may have to unassemble the diff. to check, also check the bearings too.
Did you car crashed before?
blee is offline
Old 11-08-2008 | 06:59 PM
  #1460
Rick Vessell's Avatar
Shimming your diffs is not unusual. I've had to shim the diffs in every car I've ever built.
The stock belts are tight. The KFactory ones free up the car a lot and don't require you to cut the teeth.
Rick Vessell is offline
Old 11-09-2008 | 05:47 PM
  #1461
I just purchased this kit. It was like this out of the box. Do you recommend unassemble this kit and put it together again?
cvccsi is offline
Old 11-09-2008 | 05:49 PM
  #1462
Did you shim the diffs on your E4?
cvccsi is offline
Old 11-09-2008 | 07:24 PM
  #1463
blee's Avatar
Smile
I have E4, E4RS, E4FS, E4JS in home and I don't have any problem as you mentioned.
Yes, you may disassemble the diff. and take a look whether the assembling was correct.
blee is offline
Old 11-09-2008 | 08:14 PM
  #1464
t4m1y4niac's Avatar
guys, i just bought E4 JS..handling is good..so agressive in turning..but i had a problem when i want to install my brushless motor or install a silver can motor...is there any hop up from TM or KF so my BL motor can fit to My E4JS??? thanks.
t4m1y4niac is offline
Old 11-09-2008 | 10:05 PM
  #1465
blee's Avatar
Some BL motors didn' fit into the car because the motor can is too long. I am using Novak and Orion BL motor and have no problem. However, I have told TM to improve this problem. I believe they will have option later.
blee is offline
Old 11-10-2008 | 03:59 AM
  #1466
slakr's Avatar
I have a Trinity Duo 17.5BL motor from eXpress motorsports in my E4JS...
slakr is offline
Old 11-10-2008 | 07:06 AM
  #1467
Yes. You want just a tick of side play so the bearings don't bind up. Out of the box they're too loose in the bulkheads. Manufacturing tolerances will always create a little slop in any part to part fit. That why we have shims to begin with. There's nothing wrong with your kit. I'd be more worried if you didn't have some play between the bulkheads. One good hit could move the bulkhead and bind the diff up. You wouldn't know until the run was over and you burned up a perfectly good bearing.
Old 11-10-2008 | 10:22 AM
  #1468
Thank you guys for all the info.
cvccsi is offline
Old 11-10-2008 | 07:06 PM
  #1469
t4m1y4niac's Avatar
i'm using Noval motor BL...maybe i'll wait for the hop up from TM..
thanks a lot guys..
Old 11-11-2008 | 04:36 AM
  #1470
liljohn1064's Avatar
thanks a lot guys..
I'm running Novak SS17.5s in both of mine for VTA.
What I did:
1. Take off the chassis stiffening brace.
2. Pull the sensor wire through the belt.
3. Install the motor. I had to massage it in due to the motor shaft, but it works.
4. Put the brace back on.
5. Tie wrap the sensor wires to the motor wires leaving enough loop to not rub the belts. It works nice, doesn't pinch any wires and the belts never touch the sensor wire.
This leaves me with about an 1/8" gap from the endbell to the chassis.
liljohn1064 is offline
