Like Tree3Likes
Tamiya TRF415
Old 03-29-2006 | 11:37 AM
  #13606
Stein Tumert's Avatar
Default TA05 center shaft for MSX
Originally Posted by Guo Chean
hey anyone can show a pic how to put the TA05 center pulley with the shaft into 415 center shaft. i have try to put in but cannot fit properly, thanks
We posted this yesterday, but here we go again...
These are the TA05 parts you need for the MSX fixed center pully conversion
- 51214 Centershaft
- 9808019 Centershaft-C-rings
- 9808018 Centershaft-Spacer (alu 2,8mm wide)
- 51213 Centerpullys (2pcs.)
- 3455870 Spurgear-holder
- 53874 precision-bushing (1pcs.)
- 9805672 BB 840 (2pcs.)
- 51211 Spurgear-screws
- 53586 spacer for centershaft
Stein
Stein Tumert is offline
Old 03-29-2006 | 12:14 PM
  #13607
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note we got a few of the 4mm graphite chassis for the 415 in stock. The chassis also comes with hinge-pin so any verison of the 415 should work with this chassis
Steve Wang
SpeedTech is offline
Old 03-29-2006 | 12:29 PM
  #13608
Turbonium's Avatar
hmmm.... i got mine yesterday from Tamiya themselves, but no hingepins in the pack. maybe i better make a call. any ideas?
Turbonium is offline
Old 03-29-2006 | 01:22 PM
  #13609
Ballsie's Avatar
Speedtech sorted me out with a 4mm chassis - very impressive part and service!
Ballsie is offline
Old 03-29-2006 | 04:29 PM
  #13610
Carl Giordano's Avatar
- 51214 Centershaft
Stein
Stein...thanks for the parts listing and photo...I still do not see how the 415 centershaft pulley unit is 8-9 grams heavier than the TA-05 parts listed. (someone referenced this earlier) Has anyone weighted the two units? If there is not a substantial weight saving I would think its easier to just use the 415 center pulley units and the TA-05 diff pulleys. ? Just a few thoughts
Carl Giordano is offline
Old 03-29-2006 | 04:32 PM
  #13611
Fred Hubbard's Avatar
Originally Posted by SpeedTech
Hi Guys,
Steve Wang
DOH!!! I knew I forgot something!!!
Fred Hubbard is offline
Old 03-29-2006 | 05:31 PM
  #13612
Sryder7's Avatar
I'm having some trouble with my oneway. I currently have a Yok diff in my original 415 and want to put my one way in, but when i do 1 side's suspension movement binds. The side that binds has a different lenght outdrive. When you stand the 2 next to each other it's 4 or 5mm taller and at least half of that sticks out when it's mounted in the car. Is this orginal or are both outdrives suspposed to be the same lenght? I Bought the car used so i don't know. IF this is orginal, i think my CVD shafts maybe different. they aren't blue, and are labelled "46" i'm guess that that means they are 46mm long. Is this the orginal lenght or are the orginals shorter? Thanks for any help you can provide.
Sryder7 is offline
Old 03-29-2006 | 06:55 PM
  #13613
Guo Chean's Avatar
guy here is the link of my Tamiya 415 MSX NIB kit for sale
http://www.rctech.net/forum/showthread.php?t=107975
Guo Chean is offline
Old 03-29-2006 | 09:17 PM
  #13614
The whole thing comes out lighter as stated earlier, for example is the pully not made of metal (like the MSX center pully)
Old 03-29-2006 | 09:30 PM
  #13615
fred you need the 2.9mm chassis
King of B Main is offline
Old 03-29-2006 | 09:37 PM
  #13616
Attached Thumbnails Tamiya TRF415-dsc00143.jpg   Tamiya TRF415-dsc00144.jpg   Tamiya TRF415-dsc00145.jpg   Tamiya TRF415-dsc00146.jpg
kai747 is offline
Old 03-29-2006 | 10:14 PM
  #13617
SpeedTech's Avatar
Turbonium,
I just checked all the chassis we have in the back (yes, 10pm, I'm still here ) and all of them have a pack of hinge-pins in there, so I give Tamiya a call right away tomorrow
Steve Wang
  #13618
SpeedTech's Avatar
Thank you Sir
Steve Wang
Old 03-30-2006 | 12:21 AM
  #13619
the cvd shalfs are tamiya if they have the 46 on them try to put the pin in so its flush on both sides of the out drives because it mite be grabing on the inside of the hub or you mite have to get new out drives part no: ( 53499 ) and Univ Shaft Cross Joint set not sure on part no:
snap_u2000 is offline
Old 03-30-2006 | 12:36 AM
  #13620
Sounds like you have 1 evo4 outdrive there, get a replacement set of outdrives for a 415.
Besercoe is offline
