Old 06-01-2006, 11:08 PM   #14356
maxepower's Avatar
Talking YES!!!!!!!!!!!!!!!
Originally Posted by DOTMAN
Does anyone know if the Tamiya track will be open this Saturday?
It should be open this Saturday and the weather will be awesome! The track will have lots of traction from last week! Sorex 36's should work great!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 06-02-2006, 12:28 AM   #14357
linger's Avatar
Originally Posted by Josh Numan
I've been gettin a ton of PM's on this, so just so everyone knows, my setup from the Reedy Race should be on Tamiya USA's website tomorrow! Be sure to try it out!
Josh - you are soo dialed.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 06-02-2006, 02:14 AM   #14358
Its not up YET...!!!
Ben.C is offline   Reply With Quote
Old 06-02-2006, 09:05 AM   #14359
Anyone on here use the TiR spool in their 415 ? im having trouble getting my pulley on to it, looks as though the screw mounting holes have any been half threaded for some reason ???
Anyone in UK have a good set up for Stafford using a spool ?
Never ran a spool so what sort of setup changes might be needed ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 06-02-2006, 11:45 AM   #14360
stuey's Avatar
if you'r having probs with the spool you ought to send it back to them tir are top fellas they will sort it for you as setup goes not much diffrent to what you would run a one way car tends to be safer if it was me id run a one way (front only) at stafford it is low grip but you should be able to get the car settled and you will be awsome off the straight and the double apex in the mid section and also through the chicane just befoe the start straight.
stuey is offline   Reply With Quote
Old 06-02-2006, 11:56 AM   #14361
Josh Numan's Avatar
Sorry for the delay, I know the Set Up didnt get on there yet. Its actually my fault cause i tried to fax it to them at Tamiya but i messed up. Give it a lil more time and it will be on there!
Tire Sauce is...Tire Tweak with tire warmers....for about 10 min. beofr you run.
Josh Numan is offline   Reply With Quote
Old 06-02-2006, 12:34 PM   #14362
OK spool is sorted i just had to be careful and finish off the threads , so light compared to the standard one-way.
Old 06-02-2006, 12:39 PM   #14363
Leester's Avatar
Trader Rating: 21 (96%+)
Does anybody know what new belts on the 415 will do compared to older worn belts? i never figured that out but i believe someone could explain.
Leester is offline   Reply With Quote
Old 06-02-2006, 06:09 PM   #14364
swimbikerun's Avatar
Trader Rating: 100 (100%+)
I'm running a double one way with a M8 and GTX for electronics. What do you have your EPA set to on the controller and % brake set to on the ESC? I know this is a personal preference issue but I'm looking for ball park numbers. Thanks.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 06-02-2006, 08:36 PM   #14365
edracer1's Avatar
HELP
What type of drives do most of you guys run?
Front one-way?
Front diff?
Front spool?
The direct center drive or the one-way center drive?
If I run a Spool or Front Diff should I run the direct center drive?
Can I make a Front Diff out of the rear diff parts or only the Yokomo parts as listed in the Tamiya site?
Thank you, Thank you.
edracer1 is offline   Reply With Quote
Old 06-02-2006, 08:43 PM   #14366
maxepower's Avatar
Talking Numan set-up
Can you post your set-up here in RC tech until Tamiya has the time to put it on a PDF file. Would be much appreciated!
Inquiring minds want to know!!!!
Old 06-02-2006, 09:09 PM   #14367
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
i need help please..
i have tamiya superstock TZ and i want to use it on my 415
what is the gearing that has good acceleration and good speed at the stretch???
nikkiesteban is offline   Reply With Quote
Old 06-02-2006, 10:13 PM   #14368
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
There was a gearing recomendation on the box, Have you tried that?
tamiyarcracer is offline   Reply With Quote
Old 06-03-2006, 12:54 AM   #14369
not yet.. but what will be the effect it it use smaller pinion and large pinion??
smaller pinion = better acceleration??
bigger pinion = more top speed??
is this right?
Old 06-03-2006, 01:41 AM   #14370
t4m1y4niac's Avatar
is this right?
you're right... carefull with over gear issue.
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
