Tamiya TRF415
Originally Posted by mini master
E.J.,
Is that what you and jimmy ran at Stockton? Who's car is in this picture?
Can you post your set-up for us? Thanks!
whats up EJ. hope things are good.
I think this is Jimmy J's car..
http://www.pdubracing.com/2006_carpet_nats%20046.jpg
looks like a 4mm chassis, MSX, standard suspesion.
Nexus. That's TRF Dominic's chassis. You can tell by his shamrock Jimmy's car has blue electronics and if it's in the pits...it's usually in pieces cuz he's always wrenching
Originally Posted by Hebiki
timmy.. the car pictured is EJ's Spintec and Spektrum. two of his sponsors.
It's not very pretty probably goes well tho
Does any one use the Adjustable Ball connectors (for Damper Attachment) on there 415? The Tamiya part number is 53488. Just wondering what peoples opinion on these are.
Hey, does anyone have a picture of there 415 with a GTX on the car? im trying to think of a good way to put one int (i have original 415)
hey i was just was asking if any one runs the RC Pro-Module Rr Susp Set on there car and is it better then the standed metal rear hubs and standed arm
thanks matt
thanks matt
I ran it last year outdoors and liked it quite a lot. When indoors season started I had to take it out the car because i couldn't find a decent setup for it. Now that the outdoors season is restarting I'm gonna try it again for sure.
What ratio will you get by using white TA05 Pullies? 36T pullies with 16T mid. Is there a formula? = 2.XX
large divided by small = 2.25
Thanks Alan.
I forgot, was the mid pullies on the TA05 16T or 17T?
Thanks Alan.
It's the same as the normal 415 one at 16T
Does anyone know if the 4mm chassis is drilled for the MSX center post which is attached to the rease MSX bulkheads?
MSX Versions
Hi Guys, Just picked up a second hand MSX, and was wondering if there is any difference between the MSX and the refine 2? Bit disappointed when the car arrived. Doesnt the MSX come with the LW reversible suspension?? This one has the std hard arms on it. It also came with spare 0 deg alloy uprights, but the bearings look to be alot smaller than the std axle bearings. Can anyone advise me on what size these bearings are?
At least i now have majority of the MSX gear. I think i paid too much for it for what i got tho. Looks like ill be buying the LWR suspension kit soon.
