Old 03-28-2006, 01:17 PM   #13576
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by Carl Giordano
415boy & axle..thanks for the response. I now understand the issue...with using the 415 front one-way and TA05 pulley....has anyone tried to used the front one-way for the TA05 on a 415MSX? Not sure if they are the same.
I will most likely use the Tamiya spool up front so I won't have this problem...your feedback helps if I decide to use the front one-way. Thanks
So now if I use the front spool, I need to get the TA05 locked center pulley. To get the proper 2.25 drive ratio which everyone is looking to achieve.
Or....I can just stick with the stock 415 stuff...although the white diff pulley's look trick
No problem Carl, Ill be hitting you up for answers when my MRX4 arrives
any full assembly from the TA05 wont fit in the 415 as the front belt in the 415 runs down the centre, and the 05 is offset. So thats why they are putting the 05 pulley on the 415 spools and one ways. I think thats what you were asking??? Shouldnt matter if your using the spool or the oneway on the 415, you can still use the TA05 one way pulley on the 415 parts. I just bought a set of 415 pulleys a few weekends ago, and Keith Yu then shows me his MSX at a recent race event and tells me how much better the TA05 pulleys are on the MSX.... doh!
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-28-2006, 01:26 PM   #13577
Charles Godwin's Avatar
Has anyone got a good tarmac rain set-up on pitshimizu narrow tyres , i think it is going to rain this weekend and i can't go on Saturday to test. Here is a link to the track
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-28-2006, 02:30 PM   #13578
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by TRF415boy
You can either use the 415 or TA05 pulleys on the layshaft you'll have the same ratio.
thank you...I did not realize this??? So the 415 layshaft pulley (either fixed or dual one-ways) are the same # of teeth as the TA05?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-28-2006, 02:32 PM   #13579
No problem with the MRX4 question...are your planning to travel to the GLC race this summer? If yes, feel free to stop by for some tips
Old 03-28-2006, 02:40 PM   #13580
TRF415boy's Avatar
YES
TRF415boy is offline   Reply With Quote
Old 03-28-2006, 02:45 PM   #13581
axle182's Avatar
YES
But from what i heard, the reason Marc etc are using the TA05, its lighter. that was probably mentioned earlier, but im too slack to re-read it all lol.
Aaron "AJ" Freind
Old 03-28-2006, 02:46 PM   #13582
axle182's Avatar
GLC is a possibility. Ill PM or email you if plans are made. Thanks Carl
Aaron "AJ" Freind
Old 03-28-2006, 02:58 PM   #13583
TryHard's Avatar
Charles
Best tip I was told regarding a wet set-up.... just use your dry one with wet-tyres Guess who told me that ???
| THard.co.uk | Xray | MuchMore |
Old 03-28-2006, 05:31 PM   #13584
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I just figured a dry setup with more droop and more ride height would be the go for a wet setup, but we don't race in the wet here in Australia, much to my disgust.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-28-2006, 06:22 PM   #13585
dodo's Avatar
Send a message via Yahoo to dodo
it should be lighter but maybe by a bit only and i don't think my fingers sensitivity is anywhere near Marc's that i can feel the difference
dodo is offline   Reply With Quote
Old 03-28-2006, 08:14 PM   #13586
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
higuys out there...,.. im have my trf 415 for the 1st time.. im planning about to use it on tamiya super modified 11t... what is the recommended pinion and gear for that...? i want top acceleration and full speed. tnx...
nikkiesteban is offline   Reply With Quote
Old 03-28-2006, 10:06 PM   #13587
Burlap's Avatar
Send a message via MSN to Burlap
Ummm, with gearing it is either acceleration or top speed. Especially with different wound motors.
Burlap is offline   Reply With Quote
Old 03-28-2006, 11:06 PM   #13588
I'll try that on Sunday then....if it rains
Cheers, Charles
Old 03-28-2006, 11:55 PM   #13589
ok how bout this... i want a good acceleration and a top a lil bit top speed....
what shud be the gearings.?
Old 03-29-2006, 12:19 AM   #13590
FBJ's RDX's Avatar
Do you run your car in a track or parking lot? We need to know how long is the straightaway to determine the gearing or you will just end up burning your motor. If you have been to the PS1 track, you gear it at 7.3, that's 32Tpinion and 102Spur. I hope this helps.
FBJ's RDX is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
