Old 01-02-2005, 02:28 PM   #6106
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
they were easy to make... just the measure, then cut.
and you may be right... they stick really well, but im sure mine are more likely to come off. the diff grease may get on the back and loosen them...... maybe i shouls run a tiny bit of ca aroungd the outside edge... hmm....
sure, i can make more. i made 2 sets this a.m.... just takes a few minutes. im deciding on wether to bring this thing with me. its not very big, and can be run with my laptop.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-02-2005, 02:28 PM   #6107
TryHard's Avatar
Originally posted by MR JOLLY
tryhard
I thinking along the lines of EA prs gears, what would be usfull?? for what car
i suppose all of them
yup guess so
For us tamiya drivers (and i guess most shaft cars) the smaller spurs would be a good bet, like around the 100 tooth ranges. for other cars, say such as the X-ray, I guess the larger styles would work best.
I just know that if tried to get some of the spurs that people run on x-rays to fit in mine, it would be grinding along the track... It just won't take the larger spur gears.
looking again at the PRS stuff, I would say get the TC3 and Xray sets, that'll probably cover the needs of most people (who aren't pedantic like me, and has to have every combination possible )
Thinking about it, i don't think I've ever used a pinion larger than 32t, but then again, I have been racing indoor mostly.
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-02-2005, 02:33 PM   #6108
s2
s2's Avatar
the biggest 48dp spur thatll fit a 415 is 80, an 81 will fit but is stupidly close to grounding out if the chassis is flat, just as a guide
s2 is offline   Reply With Quote
Old 01-02-2005, 02:43 PM   #6109
TryHard's Avatar
thanks for that stew, useful to know. Any idea what that relates to in 64dp gears?
BTW i have to admit to something... I was so impressed with how you'd preped your chassis edges on your car (sad aren't I ) that I've done the same to mine, all nice and rounded... makes it feel like a new car
Took a while mind, and I covered myself (and my parents lounge carpet ) with carbon dust, but well worth the effort.
And too Arun and Tamiya driver, what sizes are you cutting you sheet? internal Diameter mainly. I've been looking at doing a similar thing with mine, but i notice the outdrives are slopped slightly, in exactly the place where I want to mount the sheets. how'd you get round this problem?
thanks in advance
Regards
Ed
Old 01-02-2005, 02:46 PM   #6110
V12
V12's Avatar
There are some vinyl diff covers from Team Atlas and they work very good.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 01-02-2005, 02:52 PM   #6111
s2
s2's Avatar
no, i dont use 64dp much, was abit expensive to buy loads of 64dp stuff when id already got a big selection of 48dp.
haha thanks, my chassis roundness has got a bit chiped lately from running outdoors and riding kerbs
Old 01-02-2005, 02:53 PM   #6112
Turbonium's Avatar
my circles are .8 by 1.35 inch...
i started at .75, but it was slightly too small, and rubbed the outdrive. these at .8 leave a small gap, but shouldnt rub.
Wes
Team Novak
Old 01-02-2005, 03:35 PM   #6113
razzo's Avatar
Send a message via Yahoo to razzo
BTW...
How many 415 drivers are going to Novak TC race this week?
I'll be the guy from MN with all Tamiya'd out pit area Look for the blue glow!
razzo is offline   Reply With Quote
Old 01-02-2005, 03:38 PM   #6114
Turbonium's Avatar
uh... me.... although, i am bringing an Evo IV, and a Evo III as a backup.
one other guy from here runs a 415.
on that note, what oil you guys run on carpet with rubber tires? i am trying to get a little prepared, since we have no carpet here. i have 2 or 3 hole pistons, too...
Wes
Team Novak
Old 01-02-2005, 03:41 PM   #6115
TryHard's Avatar
ahh I see, you have mounted then directly to the pulley?
Old 01-02-2005, 03:43 PM   #6116
Turbonium's Avatar
yup... they stick to the outside rim of the pulley. i also figure that the adhesive indsie may attract the dirt that gets in there, and contain it too... maybe. good theory.
ill know more after this weekend...
Wes
Team Novak
Old 01-02-2005, 03:46 PM   #6117
Phil C's Avatar
thanks in advance
Regards
Ed
Hehe stew pursuaded me to do it also, an i gotta say it does make the car look alot nicer. After that i decided to do it to my 12th aswell hehe. It does make a hell of a mess tho dusnt it an the ground carbon stinks! lol
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 01-02-2005, 03:46 PM   #6118
TryHard's Avatar
cool, I'll pop down to my LHS on tuesday and make some of my own up, something that'll prove rather useful given the amount of carpet racing I do (damm rubbercrumb gets everywhere!!!)
And phil, it's soo true, it gets everywhere! I think I went through about 3 sheets of medium grade paper doing it, as well as the 100 top tv moment of '04 on channel 4! hehehe....
oh and as quick pic, this is what us english mean with the rounding.... look at the shock tower
and all the other carbon plate has been done the same.....
Ed
Old 01-02-2005, 04:12 PM   #6119
razzo's Avatar
Tamiyadriver, you need to bring the 415! It's fastest Tamiya car on carpet. Far as oil, on 415 for rubber we were running 50F 40R with 2 hole pistons. Unfortunately I'll be running foams at Novak race, but 415 just rips on carpet with rubber. Way better then Evo3. Not sure about 4, since no one's runnnig one here locally. All local Tamiya cars are 415, running indoors on carpet with foam or rubbber.
Also, debuting at Novak race will be some custom made shock towers for 415 for foam carpet racing. Lowers the upper mounts by 1.5mm, and has extra outer holes to stand the shocks up even more. When tires get down to 56mm ish with foams, current tower's too high, making the shocks too short to be able to run any droop/negative travel.
Old 01-02-2005, 04:33 PM   #6120
TryHard's Avatar
Default Kai Chassis parts
hmm, just been looking at some of te Kai chassis parts avaliable for the 415 again, and I've noticed something thats put me off them (baring the expense).. theres only one mounting hole for the steering servo! (at least on the flat bottom chassis anyway)
taken from rceasy.com
http://www.rceasy.com/images/news/kai/415fb06.jpg
It's daft, theres a variable slot hole near the centre line, but no outter hole, thats just rediculous.... I know you could use double sided tape, but i've never been comfortable with using servo tape for such an application (which is probably daft given it's name..)
Anyone used one of these chassis yet?
I did see a lwt chassis (with cutouts) that did have two mounting holes for the servo, but it was the LWT version, and I can't find out anymore information baring that on the RCeasy.com site.
Ed
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
