HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
+1 on above post!
Hey guys, I’ve been having issues with my xr10 randomly shutting down on the track, my steering stays on but the lower button light is off. I have to unplug the battery and plug it back in to get it to fire up again. Any help appreciated. It’s about a year old and I run the wgtr class with a 17.5
I have the UBEC 10A now. Should I connect both outputs to the receiver? Also, there was no mention of the green ferrite rings on the manual. Are they necessary?
On hobbywing's website they show XR10 Justock weighs 59.8g and the XR10 stockspec 2S weighs 28g, is this correct???
idbdoug
idbdoug
Yes it does weigh less, part of why its an awesome little esc.
Gotta be careful though: often, for the really light weights-ESCs, these are measured without fan, wires and caps... while the heavier ones sometimes include all or at least parts of that stuff. That's why I stopped putting too much faith into such published manufacturers' numbers, when often as not, they do not compare apples to apples but just present some marketing BS. However, this is a general observation, not specifically related to these two specific models.
I have a switch in rpm that I cant seem to tune out. About 3/4" the rpm jumps up , like a switch into second gear. I am running the Hobbywing v3.1 120amp sensored esc , 7.5t, 2s 5000mah 50c batt.
I have turned the timing and boost off and no change. Lowered the throttle curve and ran it with he default curve and no change. Also with punch on and off it makes no difference. I run on a loose track so all my initial sittings are as low as possible to aid with traction.
Still working on it . re-calibrated 3 time and still the same. When i start getting to speed up the rpms jump up and I loose all traction
Ok, I think I might of found the issue. I set my radio to 150 end point , max end point for throttle. Then I calibrated like normal with no turbo or punch and i still get the same big jump in rpm a little past 3/4 throttle.
I then set my end point to 145 and got the same jump. I set it to 140 EPA and the jump in rpms has disappeared. Problem now is I dont think my turbo is activating at full throttle now. Should it still activate if I turned the epa down? I like the turbo for the long straight at the track.
If I set the throttle epa to 140 and calibrate I get the jump in rpm back again.
Using a mxV sanwa radio.
I had a KO radio do something like that once because I would set the high points to 150. I wouldn't get turbo even after a recal and it would have a strange throttle feel. Once I went back to leaving the highpoint for TH and BR at 100 when I calibrated it went back to normal. Worth a try...
Did you calibrate the radio to 100% throttle or as much as the radio has? Only doing it at 100 limits some smoothness in throttle in my opinion.
new to hobbbywing speedos and recently purchased the Xerun XR8 sct for my scte truck and also ordered the trinity 4 pole motor. I am having problems with the sensored feature where when the sensor wire is hooked up the speedo will just flash red, but when disconnected in runs fine but not in sensored mode. Is this normal for this combo or am i missing something.
