HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 12-05-2017, 04:49 PM
  #12136
Trader Rating: 27 (100%+)
Increase your endpoints. Also check that the Dual Rate is at 100 as well. I'm sure you've done all of the above. But even the best of us over look thing's from time to time.
Jwilliams5 is offline
Old 12-05-2017, 06:22 PM
  #12137
Yep, checked radio, D/R EPA all set to 100%
tekin112000 is offline
Old 12-05-2017, 06:27 PM
  #12138
I’ve had instances where certain radio esc combos. (Not saying yours particularly) but I had to set it past 100% my old 4pksr had to be set to 140% then it would calibrate.
Old 12-05-2017, 06:47 PM
  #12139
I did try adjusting throttle EPA, it did change how the throttle reacted, but it still did not have brakes
Old 12-05-2017, 06:51 PM
  #12140
Sounds to me as if you have a bad esc. Otherwise DOA. You can fill out an RMA at Hobbywingdirect.com. There you will be prompted with a series of questions and be given an RMA number. They should take care of you as Hobbywing has very good customer service. Hope you get the issue resolved.
Old 12-05-2017, 06:57 PM
  #12141
gigaplex's Avatar
Have you double checked that you don't have ABS brakes enabled on your radio?
gigaplex is offline
Old 12-06-2017, 03:21 AM
  #12142
yes ABS is NOT enabled
Old 12-07-2017, 03:21 PM
  #12143
Slotmachine's Avatar
Originally Posted by tekin112000
It should but it does not. I have had many other HW products all have worked
Neutral one beep, full throttle two beeps, full brake nothing
Did you reverse the throttle on the radio and try it?
I have seen at times if you make a new model in the radio and start over with binding to the receiver then reverse throttle, set end points all the way up and finally re calibrate and it works......
Slotmachine is offline
Old 12-07-2017, 04:06 PM
  #12144
Deleted the model from the radio and created new model profile.
Re-bind TX to RX
Able to calibrate
Must have been corrupted model profile in radio memory
Thanks to all who gave advice
Old 12-08-2017, 08:41 AM
  #12145
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
So who has used the XR8 SCT ESC in E-buggy (not lite)? Looking to swap the XR8 Pro for an SCT to lose weight. Still want to run a 2000KV motor and 4S 6500 mAh 100C battery. I do not forsee any issues, yet have not run the SCT before, so just wanted to be sure. As an FYI Servo voltage will be 6.0V.
1/8 IC Fan is offline
Old 12-08-2017, 01:07 PM
  #12146
Trader Rating: 33 (97%+)
I've been using the XR8 SCT Pro in my Tekno EB48 for about a year now with 2000kV motor on 4S and very happy with this setup
1/8 IC Fan likes this.
billdelong is offline
Old 12-08-2017, 05:55 PM
  #12147
I have a new XR8 SCT Pro. Can I use the LCD Prog Box to see Motor and ESC temps after a run?
dannym is offline
Old 12-09-2017, 10:13 AM
  #12148
Yes you can. I never have but it will show you temps
Old 12-09-2017, 11:20 AM
  #12149
a1
can anyone link me to how the 2 stage punch works on the 3.1 120amp esc? Obviously its two stages but could use a little more help on when they kick in.
a1 is offline
Old 12-09-2017, 02:33 PM
  #12150
DirkW's Avatar
Manual, item 2A: you set the switching point between 1st and 2nd stage punch with a range of 1-99% (in 1% steps) of throttle position.
DirkW is offline
