HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 12-20-2017, 09:56 AM
  #12181
Does anyone leave the wifi express module in your car for races? Are there and real world negatives to this for racers that do not crash much.... I like the idea of instant tuning..... Thoughts?
SouthFloridaApp is offline
Old 12-20-2017, 11:23 AM
  #12182
Slotmachine's Avatar
Originally Posted by peakman
new to hobbbywing speedos and recently purchased the Xerun XR8 sct for my scte truck and also ordered the trinity 4 pole motor. I am having problems with the sensored feature where when the sensor wire is hooked up the speedo will just flash red, but when disconnected in runs fine but not in sensored mode. Is this normal for this combo or am i missing something.
Make sure The sensor wire is good. Then check to see if you can set the speedo into hybrid mode Instead of full sensor mode.
Slotmachine is offline
Old 12-20-2017, 11:57 AM
  #12183
tried a couple of different sensor wires using both modes and the same thing happens.
peakman is offline
Old 12-21-2017, 11:36 AM
  #12184
Have you tried a Hobbywing motor? Sometime speed controls work better as a set.....try the new #3652 g2 4 pole motor. I suggest the 5100kv and its ROAR Legal
https://www.hobbywingdirect.com/collections/xerun-3652-3660-g2-sensored-motor/products/xerun-3652sd-motor?variant=34319765969
Old 12-21-2017, 12:06 PM
  #12185
thanks
peakman is offline
Old 12-27-2017, 04:58 PM
  #12186
tony montana's Avatar
Trader Rating: 76 (100%+)
Question, just bought a just stock xr 10 60 amp. Gonna be running some 17.5 buggy and really don’t know much about the esc. I know it’s zero timing but can you adjust other things like drag brake etc on it?
tony montana is offline
Old 12-27-2017, 05:35 PM
  #12187
Set
Originally Posted by tony montana
Question, just bought a just stock xr 10 60 amp. Gonna be running some 17.5 buggy and really donít know much about the esc. I know itís zero timing but can you adjust other things like drag brake etc on it?
You can adjust
1. Running Mode
2. Drag Brake Force
3. Cutoff Voltage
4. Start Mode (Punch)
5. Max Brake Force
6. Max Reverse Force
7. Initial Brake Force
8. Neutral Range
9. Overheat Protectio
Set is offline
Old 12-27-2017, 05:54 PM
  #12188
Trader Rating: 281 (100%+)
Originally Posted by Set
You can adjust
1. Running Mode
2. Drag Brake Force
3. Cutoff Voltage
5. Max Brake Force
8. Neutral Range
With a program box of course.
Andy Koback is offline
Old 12-27-2017, 06:13 PM
  #12189
Thanks for your help Andy
Old 12-27-2017, 06:51 PM
  #12190
Set
doesn't need one for justock
Set is offline
Old 12-29-2017, 03:50 PM
  #12191
Looking for some help with a futaba 3pv transmitter and hobbywing xr10 esc. I am trying to setup the neutral, forward, and reverse. When I hit the set button on the esc for neutral, it blinks green and is fine. When I go to full forward throttle and hit the set button, it does nothing, same with reverse. I dont know what else to try?
fasteddie1 is offline
Old 12-29-2017, 04:27 PM
  #12192
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Check your instructions usually it will tell you to (for Futaba) reverse the throttle, just double check. If that is the case, go in the menu and do the "servo reverse" for your throttle.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-rev.jpg
1/8 IC Fan is offline
Old 12-29-2017, 06:28 PM
  #12193
I found the problem. The fail safe was on. As soon as I turned it off I was able to program my throttle.
a1 likes this.
Old 12-29-2017, 09:42 PM
  #12194
New HW user a bit frustrated. Boost and Turbo timing directions in manual are not the same as what options are able to be set on esc (xerun 120a V3.1) All tbe boost options in manual are not there. plus been trying to update wifi link software for days it always stays at 0% see attached.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-screenshot_20171230-003819.jpg
CNEPACE is offline
Old 12-29-2017, 10:21 PM
  #12195
a1
how do you access the data log on the v3.1? I have the program on my computer but the info not there. Do I need to run the car , and with out turning off or unplugging battery hook up the usb cable?
a1 is offline
