HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-11-2013, 03:52 AM
  #4666
I should also mention that it's in a scte losi that I am replacing the stock motor and esc. The stock motor and esc worked fine when removed just wanted it to be faster.
Revo3371 is offline
Old 11-11-2013, 03:57 AM
  #4667
Trader Rating: 21 (100%+)
do you have your throttle endpoints and trim reset?
mulepic is offline
Old 11-11-2013, 04:19 AM
  #4668
Yes I do
Revo3371 is offline
Old 11-11-2013, 07:05 AM
  #4669
fq06's Avatar
Not sure on the setting in the HW ESC but for that spectrum radio you probably need a wide neutral width for the ESC to find center.
Whatever your at now bump it up a lot and see if it calibrates. If it does, reduce neutral width until it doesn't calibrate and then you found your number... go up a hair, calibrate and you have the narrowest neutral width you can run.
fq06 is offline
Old 11-11-2013, 06:41 PM
  #4670
5th wheel's Avatar
Hello
okay I just ordered the hobby wing xerum v3.1 and I hope it will fit in the b4.1 side tray. If not I am screwed over myself lol. Know one could tell me before I order if it would fit so all I can do now is try. I just hope it's a good esc it's my first hobby wing just trying something new this thing cost a lot. ?
5th wheel is offline
Old 11-11-2013, 09:06 PM
  #4671
xrayrc's Avatar
Trader Rating: 63 (100%+)
Will the 120amp v2.1 run the hobbywing 4000kv 4pole motor
xrayrc is offline
Old 11-12-2013, 05:46 AM
  #4672
rcboy1's Avatar
Originally Posted by 5th wheel
Hello
Yes it will fit with plenty of room. I have one in my rb5 which is narrower and its perfect.
Yes it will
rcboy1 is offline
Old 11-12-2013, 06:10 AM
  #4673
Hello
You'll definately like the v3.1 . I haven't met a person that doesn't like it. For the amount of settings it has it has a small footprint .Good choice . Take the time to learn the esc setting it can be a great advantage .
Losi57 is offline
Old 11-12-2013, 06:13 AM
  #4674
Originally Posted by zuki250
I am running a 2s...i am not going to run a 3s.....maybe an external bec?
An sct pro would have been the better choice . But you'll be fine with an external bec.You cannot adjust the bec in the 150 a esc.
Losi57 is offline
Old 11-12-2013, 06:32 AM
  #4675
5th wheel's Avatar
Thanks guys for The help and informaTion. hopefully it will be delivered Friday. be prepared I'm new to hobby wing ESC so I may have a lot of dumb question so if you there with me I will appreciate it. any help I can get from the guys that know is very helpful. I am new to hobby wing an off road racing. been using Novak stuff. and it looks like the the 3.1 is a little more complicated than the Novak edge.
Old 11-12-2013, 07:01 PM
  #4676
Just got the 3.1 stock version how do I turn off the dual punch I just want a smooth throttle pull not slow the all of a sudden full throttle! Thanks
bigdog is offline
Old 11-12-2013, 08:47 PM
  #4677
Nevermihd! I was a dumb dumb and forgot to plug in the sensor wire!! Lol it's fine now!
bigdog is offline
Old 11-12-2013, 09:20 PM
  #4678
FastPete's Avatar
Trader Rating: 44 (100%+)
Glad you figured it out!
FastPete is offline
Old 11-12-2013, 11:12 PM
  #4679
BmainStar's Avatar
Your user name makes me laugh because it reminds me of Skinny Pete on Breaking Bad LOL.. I have a question? Any tips for cleaning the 4000 kv 4- pole 3656 motor? And how often should this be done? Thanx in advance, Cheers!
BmainStar is offline
Old 11-13-2013, 04:24 AM
  #4680
I race twice a week. I like to replace bearings and clean every 3/4 months.
Losi57 is offline
