Like Tree4Likes
Viper RC -
Old 07-04-2015 | 08:18 AM
  #11836
Baja-Boy's Avatar
Originally Posted by RBraswell
I noticed a drop in price for black edition motors also...which is concerning. I saw this happen with team durango products right before they cut the team support and discontinued a few vehicles.
I love my viper electronics. Hope this is just a superficial bump in the road or a facelift.
I can promise you no one is turning off the lights or packing up...
I'm sure Nick will chime in.
Baja-Boy is offline
Old 07-04-2015 | 10:25 AM
  #11837
Having trouble getting drag brake to set with the programmer on vtx10 it will set but will not stay set when I push the load settings key.
Tas4 is offline
Old 07-04-2015 | 10:34 AM
  #11838
DustinH's Avatar
After you change it you have to save it.
DustinH is offline
Old 07-04-2015 | 11:33 AM
  #11839
The load key will only load the current profile selection.
When making changes you need to use the save settings.
micrors4guy is offline
Old 07-04-2015 | 05:25 PM
  #11840
Tried the save button still did not work I may have a bad programmer.
Tas4 is offline
Old 07-04-2015 | 07:30 PM
  #11841
bds81175's Avatar
Moderator
When you change the setting make sure you hit OKAY on that page instead of EXIT. If you hit EXIT, it will revert to your previous setting.
bds81175 is offline
Old 07-05-2015 | 12:44 AM
  #11842
Baja-Boy's Avatar
Can you explain your proccess from plugging in the pro-gauge or EZ-link on?
You need to click change setting, change the setting you would like, hit OK, then hit the save setting, unplug, and tap programming button.
Baja-Boy is offline
Old 07-05-2015 | 01:34 PM
  #11843
Got it figured out guys the programmer lead was not making good connection thanks.
Tas4 is offline
Old 07-10-2015 | 08:03 AM
  #11844
BigInJapan's Avatar
hi all. can anyone help me decode what may be going on here, VTX10R BE with a Tekin 6.5 turn was running fine at first, then stopped in the middle of track. esc showing solid red light on the F and solid green on the N. cant access programming and the only way to turn it off is by unplugging the batteries/doesnt respond to any button/ez link inputs, except turning on. motor beeps twice turning on, then no throttle/no response. have tried sensor leads. any advice?
BigInJapan is offline
Old 07-10-2015 | 08:49 AM
  #11845
orangutanracer's Avatar
You might be in Radio Calibration mode.
orangutanracer is offline
Old 07-12-2015 | 05:19 PM
  #11846
Default How much timing?
Hey guys. I have a Tekno sct410 running a viper vf4.40 4 pole motor and want some more top end on the back straight. How much boost or esc timing can I add to this motor before the timing is no longer effective or it is detrimental to the motor or esc?
red100076 is offline
Old 07-12-2015 | 06:52 PM
  #11847
Baja-Boy's Avatar
Depends on temps etc. You could try a tooth taller gearing and no timing, or try slowly increasing timing. Not much timing im sure, timing is a real heat builder
Baja-Boy is offline
Old 07-12-2015 | 09:24 PM
  #11848
I'm only hitting 130 degrees after 8 minutes on the track, so I have some room to push it harder. I thought about going up a tooth on the pinion gear but I don't want to loose any out of the hole. I did go from 0 degrees to the tekin rx8 default of 3 degrees and there was a noticeable increase in the top end. I'm just not sure what is considered low or high timing. One of the default modes in the rx8 has somthing like 20 degrees of timing. Is that low or high?
Old 07-13-2015 | 08:24 AM
  #11849
nikos2002's Avatar
Adding boost and timing is difficult with 4 pole motors as they are already tight on motor temperature so adding timing is tough. Not highly recommended. if you do - very little.
nikos2002 is offline
Old 07-13-2015 | 08:28 AM
  #11850
nikos2002's Avatar
Huge shout out to Douglas Hobbs and Stephen Butler!!!
Stephen TQ the 17.5 Intermediate class at the J Concepts Indoor Nationals. Douglas would qualify second.
In the main, Douglas would get around Stephen on the first lap and take home the win.
Both were running Viper Black Edition 17.5 motors with BE11 High Torque rotors. These things are some of the fastest motors around and they only cost $65!!!
