Like Tree4Likes
Viper RC -
Old 07-13-2015 | 08:56 AM
  #11851
Originally Posted by nikos2002
Adding boost and timing is difficult with 4 pole motors as they are already tight on motor temperature so adding timing is tough. Not highly recommended. if you do - very little.
What do you consider very little timing?
red100076 is offline
Old 07-13-2015 | 09:04 AM
  #11852
Default VF4.40 sensor loose?
Last night while I was working on my SCT410 I noticed that the end bell that houses the sensor board and the end bearing was really loose and the 3 screw were backed out around 1/8". I disassembled the end of the motor to make sure nothing was damaged, everything looked okay. A few more runs and I think I would of had a major problem on my hands. My question is, should I use some locktite on the end cap screws? Or just check them after I run?
Old 07-13-2015 | 09:11 AM
  #11853
Huge shout out to Douglas Hobbs and Stephen Butler!!!
Stephen TQ the 17.5 Intermediate class at the J Concepts Indoor Nationals. Douglas would qualify second.
In the main, Douglas would get around Stephen on the first lap and take home the win.
Both were running Viper Black Edition 17.5 motors with BE11 High Torque rotors. These things are some of the fastest motors around and they only cost $65!!!
Congratulations on the TQ. Thats not the first time I have heard how fast these motors are, I may have to pick one up for my B5m lite that I just started to assemble. Are they ROAR approved?
Old 07-13-2015 | 07:40 PM
  #11854
bds81175's Avatar
Moderator
Locktite those screws. I haven't had mine back out but I'll need to keep an eye on them. Great motor!! I've got the 4500 and it is a beast!
bds81175 is offline
Old 07-13-2015 | 10:10 PM
  #11855
nikos2002's Avatar
Haven't seen an issue with them backing away before unless there had been some force against them. You wouldn't believe how much 4wd SC chassis twist and flex. All that force has to go somewhere.
nikos2002 is offline
Old 07-15-2015 | 06:39 AM
  #11856
blackshark3's Avatar
My favorite shop have a VTX 8 in stock at good price, can someone share their experience of VTX8 in comparison to other 1/8 ESC like Tekin RX8 Gen 2, Novak Activ 8 or Hobbywing Xerun 150? Is a newer 1/8 ESC coming from Viper? Sadly there is no information from their website...
blackshark3 is offline
Old 07-15-2015 | 06:57 AM
  #11857
Motorman007's Avatar
How much longer on the new stuff? My Yok YZ-2 needs a new ESC
Motorman007 is offline
Old 07-15-2015 | 07:27 AM
  #11858
tedstryker's Avatar
Good luck people
tedstryker is offline
Old 07-15-2015 | 07:40 AM
  #11859
The vtx8 is a great esc. however, it is not discontinued and the new stuff is in the works.
micrors4guy is offline
Old 07-15-2015 | 02:13 PM
  #11860
TruggyStyle's Avatar
Some Information for the new Stuff would be very nice. I need a new 1/8 ESC and my buddy loves his VTX8. So I would like to try a Viper ESC this time.
Will they come this year?
TruggyStyle is offline
Old 07-15-2015 | 11:01 PM
  #11861
Speaking from experience, VTX 8 trumps RX8 and Xerun 150.
VTX8 is built solidly, tuning options are fantastic and seems to be bombproof!
RX8 blew up and I've seen ALOT of them blow up
Xerun 150 would come 2nd. Solid but slightly less tuning than the VTX8 and slightly less smooth IMO but for the money is fantastic!
WagwanBumba is offline
Old 07-16-2015 | 08:37 AM
  #11862
The brushless servos are definitely the better choice especially for durability. The motors in these servos are so much more powerful and are regulated by the circuit to keep the current consumption and heat to a minimum. These servos will also not slow down under load so the speed stays the same right up to the point they can't move where the coreless servo can bog down at around half of their stall torque rating. Note: Team Driver Adam Drake uses the 9380 for throttle/brake in his Buggy and Truggy with the same for steering in the Truggy but uses the 9370 for steering in the Buggy. Other top level drivers use these servos as well even though they are sponsored by other brands due to their durability. The 93XX series use the exact same motor but with a more conservative circuit so there was no need for the heatsink and we also chose to go with steel gears vs. Titanium which kept the cost down. I use these in 1/10th applications although they would still be fine for 1/8th as well. In most cases, even in electric you won't need to use the PAD if you are using ESC's from Tekin, Novak, Castle as they can handle the back voltage from the regenerative braking circuit.
Mike Mayberry
Hitec USA.
Do you know if the viper ESC can handle this?
(can handle the back voltage from the regenerative braking circuit)
Old 07-17-2015 | 09:17 PM
  #11863
boborc's Avatar
tried calling Viper Today, No answer just rang 20 times. No machine pick up or anything
boborc is offline
Old 07-17-2015 | 09:26 PM
  #11864
DustinH's Avatar
They're moving the offices
DustinH is offline
Old 07-19-2015 | 07:33 PM
  #11865
nikos2002's Avatar
New stuff is in the works.... I don't have a date on anything yet. That's why there isn't anything on the website yet. Once we can start announcing it will be.
