Viper RC -
#4351
ESC setup
Drag Brake 20
Dynamic drag brake
9000 rpm
8% of max brake
Dynamic Curve: -Exp1
Brake Strength: 80%
Brake PWM: 3200
Brake curve: -Exp1
Throttlr PWM: 6400
Throttle punch: 100%
Throttle curve: linear
Deadband: middle
Acceleration Boost
Start RPM: 5000
Finish RPM: 18000
Max advanced timing: 33 degrees
Top speed timing
Slew rate: 12 deg./0.1 sec
Timing: 15 degrees
Delay time: 0.10 sec
Forward power: 100%
13.5 VST
Geared 76/26 (maybe 28)
#4354
Just thought I'd drop in a quick note about my Viper powered XFactory X60. After the TQ and win last week I had a bunch of people asking me how my truck was so fast yet so controllable. Nobody believed me that I was running a 10.5 with no timing on the esc.....put it in Blinky mode. Motor came off after an 8 minute main at 100 degrees and had all the low and top end anyone could ask for. I let a couple guys drive it after the main, needless to say the shop owner had to order 3 10.5 combos for the guys. They couldn't believe just how smooth yet powerful the system was. 3 "converts" in 5 minutes of driving, gotta love it!
#4355
I had to fill a large order for Dirteater RC in Oregon, any chance that might be where your from
Thanks for representing Glowster21!!!!!
#4357
Now some may say I'm biased seeing that my electronics sponsor is Viper and my Chassis sponsor is XFactory, but BY FAR the smoothest, most powerful yet controllable products I've run in my 20+++ (I won't tell you exactly how many years
) years of racing. Add to that the INSANE and consistent power I get from my Speedzone USA Lipos and the setup makes even me look like a "Ryan" or a "Jared" on the track
#4359
Let me start by saying that I really like the viper system I have. Now with that said, I am in need of a stock set up for a 10r/vst17.5. I am pulling out my hair with gearing trying to keep up with even my own laps times running a different motor. I have a B4.1 worlds and I have ran 69/30 through 69/37. What I would really like to see is someones esc settings. Any help would be AWESOME!
#4360
end rpm 22000
slew-13
throttle freq. 5000
drag brake-27&
throttle expo-linear
brake expo- linear
dynamic curve- neg 1
brake-65%
punch-100%
timing-45 degrees on can, stock on speedo
the settings i left out i did not touch so they are stock in the off road 17.5 profile.
geared 72 34, was fine. I prefer 13.5 boost anyway.
#4361
start rpm 5000
end rpm 22000
slew-13
throttle freq. 5000
drag brake-27&
brake expo- linear
brake-65%
punch-100%
end rpm 22000
slew-13
throttle freq. 5000
drag brake-27&
brake expo- linear
brake-65%
punch-100%
#4362
Hello
Can you surgest for my what should we take for ours SC.We are running in big 1:8 track.
I would like to try one Copperhead combo for Slash 4x4, weight 2.6kg with T-rce chassy. Now I am running stock Velilnen 3500 and just on the straight other Slash with Tekin Pro4600 is faster when I. So which wopuld be better Copperhead 4500Kv or 5150Kv .
And we need VST XL for Losi SC. Will VSTXL 4.5 will be good for it?
CAn you explain what is main different betveen VTX10 and VTX10R
Thanks Gytis
Thanks Gytis
#4363
opio- slew rate is part if the boost settings. If you can't run boost at your track, try the other settings as a base to work from. Every track and driving style are a little different.
rcq- yes for a big track the Copperhead 5150 or
VTX10R/VST4.5 XL are good choices. They are big power motors and can be geared for big tracks. The difference is sensored or unsensored, as well as cost.
With the 10 and the 10R- the 10R can run lower turn modifieds and 550 motors. It's slightly taller than the 10, if that matters.
#4364
Thats answer I and expected.
But what about Motor for AE SC. Like I know there is not enought plase for it to place bigger motors like VST XL 4.5. It have to be VST L6.0 ? But will he have enought speed for big track.
What Current can hold VTX 10 and VTX 10r.
What About VTX 1. Is this ESC just good for 1S Lipo, or we can use sometime and with 2S. If its good and with 2S in what situation you would't surgest to use it.
4Likes
