Viper RC -
#2851
pm sent
cool so your saying if i need to send back maybe since im right here they can just do a swap ,,lol jk man id hate to think i have to pull this thing from my durango again it sucks
#2852
Hey guys i am getting back into 1/10th after a four year break and running nothing but nitro, I have just bought a viper system with and 8.5 and its going in a 22 any ideas on were i should start for gearing? ESC settings? i am lost with all this new brushlss technology. LOL. Thanks for the help
Josh
Josh
#2853
Josh
Josh
#2855
#2856
Try starting around 80-22 (depending on the track size) - check temps to see, but 2wd doesn't generally cause too much heat. If you are just getting back into electric, start with Profile 2, get used to the power band difference before you go crazy trying to make sense of the electronics - them just make simple changes at first. I rarely change the Profile 2 settings for 2wd or 4wd, except drag brake.
Matt
#2857
Awesome guys thanks for your help, on a side not i have to say that the esc and motor package looks amazing and the build qaulity is top notch and the price point man you guys nailed it, i was looking at other systems and my friend Tennison who i believe is sponsored by you guys was the one who turned me onto your equipment. Now Does anyone know what the stock spur gear is on a 22?
#2858
Is there any specific settings I should look at and change for a D3 8.5.
#2859
Ed, Profile 2, should be Modified off road no boost. That being said, all these profiles can be adjusted and saved.
jsp - I agree, we have a kick a-- graphics team!!! The boxes look awesome, you should see the iHobby booth - its rocking - again!! Check the Facebook page for pics.
#2860
[QUOTE=nikos2002;9808361]Ed, Profile 2, should be Modified off road no boost. That being said, all these profiles can be adjusted and saved.
I know that is what it was supposed to be, but when i loaded profile 2 it was blowing off my tires. when i checked the settings it had boost and timing. Was just wanting to let you know, its know big deal. Just had to re glue my tires.
Do you know if i have to change the brake or throttle freq. Or better yet what do the changes do.
Is the info on the setting changes correct in the manual?
#2861
[QUOTE=itsjusme;9808482]
Profile 2 is modified off-road non timing so that is the right setting for your D3 8.5. You might want to try turning down the throttle punch from 100%>75%. I dont know why when you checked with pro gauge it had boost active. Try the throttle boost first and hope that helps.
You can find more detailed help on the forums in our Viper website
http://viper-rc.com/forums/
#2862
Josh
Josh
#2863
hey guys thinking about trying this line of motors out, do they run as cool as s d3 or on the hotter side like the x12s? just wondering what to gear like so the temp is in check. Also any funny smell to the motor like the newer thpows?
4Likes
