Viper RC -
#2866
Within the forums on the Viper RC site an FDR of 5.6-6.9 is recommended for 17.5T with boost for TC. I was wondering what the recommended FDR (or rollout) is without boost for 17.5T and 21.5T. I am driving on ozite carpet with a TC (rubber tires).
Thank-you.
Thank-you.
#2867
Ed, Profile 2, should be Modified off road no boost. That being said, all these profiles can be adjusted and saved.
jsp - I agree, we have a kick a-- graphics team!!! The boxes look awesome, you should see the iHobby booth - its rocking - again!! Check the Facebook page for pics.
#2868
Running a 10.5 Viper and VTX10R SC in my XXX-SCT.
Noticing a lot of neutral position hesitation when going from throttle to brakes and back to throttle. In some cases on jumps hitting the brakes to rotate the nose down then when I'm down big pause before power on available.
I was running the sport mode w/ reverse.
#2869
http://www.viper-rc.com/questions.php
#2871
Ok...I'm chompin' at the bit for the copperhead 4500 4 pole with the 5mm shaft combo...I'm hoping 1 of the viper guys could give me the part number & a round about date of when they should be available please. Thank you!
#2872
#2873
Hope this helps
#2874
#2876
The FDR that i use for 17.5 non-timing in carpet is usually 3.6-4.0 and for 21.5 i heard the Viper team using the same FDR numbers. Motor timing on the end bell is max. Remember to always check the temperature after 3 minutes to make sure its safe. If the temps are low then you can gear one tooth until it reaches optimal levels (150-175*)
Hope this helps
Hope this helps
#2877
#2878
Hope this helps
Hope this helps
im using 35 / 66 atm but sounds like i can go much higher
car is an x-6
#2879
As far as I know a part # hasn't been giving to them yet..They are coming next month if everything stays on schedule.....We all are patiently awaiting this system even the Team Drivers....They are going to be in high demand by the 4X4 guys I keep getting all them asking when's it coming when's it coming......I might even have to get me a 4X4 now....lol
#2880
This past weekend was the final race of the MNRC series, in which i clinched the 10th overall spot in 1/10 2wd SCT Open, against a very fast feild of drivers in which 3 or 4 have chassis sponcers. So i am happy with my 10th, that and it was original meant to be a filler class till i kept making the A Mains.
I went with Viper half way threw the season and my results greatly improved!
I run a Losi XXX-SCT with a Viper VTX10 & VST8.5, Awesome combo!
Looking forward to next year to run Viper the whole season and bettering my results!
. I went with Viper half way threw the season and my results greatly improved!
4Likes
