Viper RC -
#3617
#3618
#3619
One word "Simple"!!! All you need to do is plug it in the receiver and your set. No more receiver packs to worry about. In blinky its just as powerful as any other system out there and in boost its incerdibly fast. We run on a huge outdoor track 140'x90 and the VTX1 boost parameters are the only system that can reach top speed down the straight
TQ and win also helps
#3621
Ran at local track today and my Viper powered Team C was awesome! TQ and managed to get 2nd in the main. I am still running loaner 20 and 25c packs till my HVR packs get in and I still ran with the fast cars no problem.
#3622
i have a sidewinder sct combo in my sc10 right now and while it has served me well, i want to go to a sensored set up. i'm looking hard at the viper vtx10 esc with the viper 10.5. i'd like to run a trinity d3 10.5 or a revtech 10.5. has anyone run this combo? please share your experience/opinion
#3624
#3625
So I purchased and installed the Viper VTX10 w/ VST10.5 a couple weeks ago. All seemed well and the setup and use of the Progauge was great. Heres the problem.
About half way through my first qualifying race, I would come off a large jump, coast a bit, grab the brakes and attempt to accelerate out of the corner. About 50% of the time the motor would not go... with a small push, it would work again great. This was intermittent and didn't present itself through the rest of the day. I ended up TQ'ing and winning.
So knowing I was losing a bit of time down the straight, I purchased the 8.5 vst, got it all setup, and hit the track. Again the problem came back, and got worse. When I would apply throttle, it would buzz, move forward like and inch and not move till I completely let off the throttle, then when I got back on, again a small "beeep" an inch, and no motor power. Would get nothing above 1/4 throttle. SO... like all frustrated people... I dropped the truck on the table, and before I took the body off, it worked again...
Also there are times that I push the power button, and it doesn't always come on...
So heres the setup:
Profile #1 (Only changed it to Open Mode and not blinky)
SC-10 FT 20/85
5000mah/20 C LiPOs
I've run roughly 5 packs through it with the old motor (10.5) and only 1 with the (8.5).
I'm thinking there is something wrong internally with the speedo or switch, as it seems that the issue is only caused on impact. I have checked all the connections, replaced the sensor wire, even took the endcap off the motor and sprayed it out with some motor cleaner (electric type). Our track has superfine dust...
Ultimately it looks like I will have to send it back, anyone else have similar issues (I see above that someone else does), know the cause, or something that might have been done during installation to cause this?
So heres the setup:
SC-10 FT 20/85
5000mah/20 C LiPOs
#3626
#3627
The profiles are saved in the ESC itself not the pro-Guage. The pro-Guage simply allows you to change the ESC settings. So you can use the pro-Guage for Multiple viper ESC's.
#3628
So little update. I put the 10.5 back on, seems to be operating ok on the bench, but won't be able to tell till I get it out on the track. The 8.5 feels rough, so I probably f'ed it up when I took the rotor out to spray out the dust.
#3630
always triple check solder joints (even on the battery or any plugs you use), crash hard enough they can come loose also.
let us know how it works. If you need to send it back, there is an RMA form on the Viper website.
4Likes
