Viper RC -
#3601
I'm just getting into the electric rc's so i picked up an older stampede xl1(NIB) and wanted to upgrade to the xl5 set up.So i changed the esc and the motor and it has all the functions,But.The light on the esc stays red.What am i not doing right ? Thanks.
#3602
I would say your best bet is to contact Traxxas customer support http://traxxas.com/support/Traxxas-Warranty-Service
#3603
Originally Posted by Cautrell05
Before I defect to another brand help me out incase Im missing something. I bought a 17.5 for my shortcourse last march. havoc pro sc, no boost, 2 cell truck weighs in at 78 ounces. I ran it all last summer outdoor fairly flat track. From the beginning it seemed short on power. The fast guys at the track were running a 7.50 final. I ran everything from an 8.00 to 7.25. 7.50 or higher it started getting much warmer and got worse on power. I tried changing timing along with the gearing and never got to a zone where it started improving. I finally settled for a 7.92 and just left it there. I did a lot of reading last spring before i went with the viper and the general thinking was to gear it up a couple teeth due to the lower kv rating. Tried that and had no luck. I looked into the batterys and thought that may have been part of it. I was running a genace 4800 25c saddle pack. Last month I picked up a couple losi shorty packs and took it to omaha for the novak race. my driving sucked due to lack of practice down there but the lack of power became real apparent. The back stretch has a set of doubles followed by a table top leading into another set of doubles. The only way i could clear the second set of doubles was to downside the table top PERFECTLY and even then it was only about half the time. I fought with that for 2 rounds and pulled the tekin 17.5 out of my buggy and put it in for the third round. The difference between the two was unreal. Real close to boosted and non boosted. The second set much easier to clear and the speed down the straits was noticably better.
So my question is simply what am I supposed to do with the viper? I dont think gearing it higher yet will make it better as the performance just dropped off the more i geared it up.
Nick
Anybody? Public or PM I dont really care but it would be nice to get an answer on this.
Nick
Yesterday 12:39 PM
IT is starting to seem that viper is trying to ignore all there problems
Nick
Nick
Yesterday 12:39 PM
#3604
1st test run with the VTX10R/6.5T in the B44.1
and sweet god it is fast
Started at 20/81 motor temp got to about 160. dropped the pinion to 19T motor temp at 130 ESC at about 110
I might try a 18/81 and see where the temps go. The track is very small so the gearing won't really hurt it but this thing is fast
One more viper system to get and all 3 trucks will be Viper RC powered
#3605
Any of you guys put bullet connectors on the 3 orange wires from the ESC to the motor for quick removal? I was thinking of just cutting the orange wires and soldering in some bullets.
Any thoughts as to why this would be BAD? If not I'm going to doit!
#3606
Nick
Nick
Yesterday 12:39 PM
Nick
Nick
Yesterday 12:39 PM
We can only work on the problems that we know about. The most direct response for help is to contact customer support.
#3607
Should be ok. Just use connectors rated to match that of the wire being used.
#3609
#3610
why quick removal? When would you need a quick removal? Idk if you do, soldering iron heats in 2 min. lol. They can come apart during the race. I had a esc that would always do that.=crap when your driving.
#3611
#3613
Just installed a VTX10 and a VST 10.5 in my truck. Properly calibrated it, but I am not getting any power to the motor. The lights are indicating forward and reverse, but no power. Anyone have any ideas on where to go from here? Not sure if there is something simple, or if I need to ship the esc to viper...
Thanks in advance.
Thanks in advance.
#3614
Thanks in advance.
Thanks in advance.
4Likes
Was doing the same thing
